Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2008, 07:35 PM   #1
Dr. Evil
CF Senior Member
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Dr. Evil's Avatar
Default LT1/4 timing chain slack
In the middle of a elec water pump install and pulled the timing cover to remove the water pump drive. The current LT4 chain has roughly 30k on it. If I rotate the crank to pull the slack out of the timing chain on the pull side I have right at 1/2" of slack. About every SBC has some slack in it but I couldnt find a spec that specifies how much is too much. Does this seem excessive?
Dr. Evil is offline   Reply With Quote
Old 04-01-2008, 09:07 PM   #2
vetteman9368
CF Senior Member
Gulf Coast Events Coordinator
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
Send a message via AIM to vetteman9368 Send a message via Yahoo to vetteman9368
Russ, when i did the electric pump on my LT-1 i did a regular (non LT-1, hyd roller) Cloyes double roller chain as i noticed the same thing you did
vetteman9368 is online now   Reply With Quote
Old 04-03-2008, 05:41 AM   #3
1981Z06Vette
CF Senior Member
Quote:
I used the same chain...much cheaper than the alternatives.
1981Z06Vette is offline   Reply With Quote
Reload this Page LT1/4 timing chain slack
Tags
chain, corvette, crank, engine, lt, lt1, slack, timing, timingn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help: anyone with LT4 extreme duty chain! sothpaw2 C4 Tech/Performance 52 11-10-2005 07:19 PM
Just got back from the track. I could just cry. Nathan Plemons C4 Tech/Performance 24 08-04-2002 11:56 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
