03-28-2008, 08:39 PM
CF Senior Member
Lt1
what can i do to get more power out of my 93 LT1 vette motor?
03-30-2008, 01:11 AM
CF Senior Member
Upgrade to LT4 specs is easy, if not cheap.
03-30-2008, 11:56 PM
CF Senior Member
03-31-2008, 12:17 AM
CF Senior Member
St. Jude Donor '05
cam, port your stock heads and intake; longtube headers and a good tune.
04-01-2008, 03:51 AM
CF Senior Member
A stroker crank is a good upgrade, and they are a lot cheaper than they used to be. You can also bump the compression considerably if you are using a larger cam. The LT1 383 in my 97 Camaro SS is 12.3:1 and runs on 93 octane. I'd have the stock heads ported, or go to some good aftermarket heads like the TrickFlows or AFR. The LT4 stuff isn't worth the money IMHO.
05-02-2008, 02:20 PM
CF Member
Even tho I'm having problems for now, I still like my 1.6 RR's. Like a mini cam swap but w/o all the hassle.
07-02-2008, 01:11 AM
CF Senior Member
I took a 92 LT1 and rebuilt as a 383 stroker. Ported heads and intake, LT headers, etc etc. Runs 11's.
__________________
383 LT1 92 auto daily driver w/165,000 miles; K&N filter, cut lid, 160* stat, 3.33 Dana44,
custom cam, ported heads & intake, 58mm throttle body, 1.6 RR's, 2800 TC, Meziere water pump,
Stainless Works LT headers, RT bullet cats, X-pipe, MT ET drag radials. Build and tune by SloRVette.
Bests: 60': 1.539; eighth: 7.30 @ 91.45; quarter: 11.553 @ 119.33; 0-60 mph: 3.09 sec
Sound of car clearing her throat here .
07-24-2008, 07:31 PM
CF Senior Member
I took my 92 and put a full forged 383 with ported afr190's, full exhaust and a vortech pushing 12psi of boost. Just over 600 hp.
08-07-2008, 01:07 AM
CF Senior Member
Quote:
Originally Posted by
cuisinartvette
What he said, with a Hotcam and 1.6 RR. I gained 50 rwhp.
10-27-2008, 11:06 PM
CF Senior Member
auctionman256
Most bang for the buck , K & N and cut out air box Quality Longtube Headers W/ x pipe and 3 in. exhaust
Everything else calls for megabucks and a low milage engine.
11-07-2008, 12:13 AM
Determine your budget/what you're willing to spend and then determine your mods. Speed is merely a matter of money.
__________________
Jim
'96 Grand Sport #007
A few mods here and there
11-08-2008, 11:18 AM
CF Senior Member
Lichen
Agreed, I see this mod alot for the Camaro's and Trans Ams out there, they do this and add headers and next thing there in the 12's. The Hotcam/RR and Headers alot of HP for your buck.
11-11-2008, 11:13 AM
CF Senior Member
96GS#007
Exactly so; there are a lot of things you COULD do - budget determines what you CAN do.
Tags
383 , 600 , 93 , c4 , corvette , engine , forum , hp , kit , lt1 , modifications , pipe , quasar , sale , stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
