Quote:
Originally Posted by BlackRocket
I am putting together an LS2 for a custom '69 Vette and was wondering if anyone has any recommendations for a flywheell (diameter and # of teeth) & clutch package set-up. This will be bolted up to a Tremec 5-speed with a Lakewood bellhousing.
Seems like Keisler has some clutch packages and flywheels, but not sure they will work with an LS2???
Thanks!
Just so you know, we do have clutches and flywheel packages that work with the LS series motors and our transmissions. We have them in 10.5" and 11" versions(153tooth and 168 tooth respectively).
How much horsepower and torque are you expecting?
Richard
Tech Support
Keisler Engineering
