Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2008, 03:43 AM   #1
BlackRocket
CF Senior Member
BlackRocket's Avatar
Default Engine Grounding???
I am assemblying a track car with very few wires; starter, electric fan, electric fuel pump, alternator, an MSD box, and a few gauges.
Everything was running fine, then after deciding to ground the engine block to the frame we began having problems...
First there were spark fron under the lower side of the crank pully to the lower frame crossmember about 1/4 " away?
We looked for any leftover wires, but only found the deactivated anti-skid wires and removed them. We cranked the engine again and then there was an electrical fire from the same area??? (No wiring is present there!)
Can't figure out what is going on??? (Should the engine have a grounding strap attached to it?)
With the battery cut-off switch in the off position killing power to everything, there is a small burst of power when I turn on the IGN switch since there is an associated light then it goes out. This may be the MSD box with stored power?
Any clues or ideas would be appreciated.
Thanks!
BlackRocket is offline   Reply With Quote
Old 03-27-2008, 03:21 PM   #2
Richard454
CF Senior Member
Richard454's Avatar
Send a message via AIM to Richard454
If you are using solid motor mounts- grounding shouldn't be an issue.
If not- the engine SHOULD be grounded-starter sees the negative side of the battery through the block-as does the alternator.
Richard
Richard454 is offline   Reply With Quote
Old 03-28-2008, 11:47 PM   #3
BlackRocket
CF Senior Member
After hours of cutting out my wiring and direct wiring the starter I found the problem....
The starter mount needed sanding to ground out.....
Old 03-29-2008, 10:25 PM   #4
Richard454
CF Senior Member
Richard454's Avatar
Lesson learned...Not that I have EVER done anything like that... well maybe my wiper motor in a C2 that is a PITA to pull out...or that rubber isolator that BMW's use on alternators to keep vibration down...
I now get out my meter and check continuity from motor/starter/alternator to ground or negative term of the battery...Usually saves me from rewiring/unbolting and pulling out what hair I have left....
Richard
Old 03-31-2008, 01:25 AM   #5
BlackRocket
CF Senior Member
Yeah, I'm no electrician, but I can use an Ohm meter to check for continuity and it all checked good.
This one nearly drove me and a buddy crazy since we had a direct wire to the starter....
Well, everything works as advertised now after buying new NAPA starter for no reason....
Reload this Page Engine Grounding???
Tags
454, engine, grounding, groung, tips
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power Wires and Grounding in a C5 noelc5 Audio/Electronics 18 05-28-2004 12:36 PM
Grounding kit: Anyone use these on a C5? APT C5 Tech 14 04-16-2004 11:39 AM
ZZZZZR1's engine work Jeffvette C4 ZR-1 Discussion 24 02-04-2004 07:27 AM
Grounding Cables work on Z (350Z) atz06 C5 Tech 17 07-23-2003 11:24 AM
ground body to engine ground connection.......proper bolting location? daily_driver C3 Tech/Performance 12 07-31-2002 09:20 AM
Wow, is my engine running hot! Sparticus C5 Tech 13 02-17-2002 09:37 PM
Service Engine Soon Light dba4life C4 Tech/Performance 9 08-21-2001 03:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
