Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2008, 01:51 AM   #1
babbah
CF Senior Member
babbah's Avatar
Default NGK Iridium Spark Plugs
I have read a lot of good things concerning the NGK Iridium spark plugs in performance engines. Many are running them is race motors....Has anyone used them in a high performance C2 Big Block? And with MSD Ignition?
babbah is offline   Reply With Quote
Old 02-28-2008, 12:46 PM   #2
Shurshot
CF Senior Member
Quote:
I run them in mine with all MSD components
NGK does their numbers backwards from others when it comes to heat range....... their hottest is a # 7 and I would not go any colder for an 11.2:1 BB like mine........ plus I am seldom in traffic
For any stop and go driving NGK recommends their normal tip plugs over the V series
Shurshot is offline   Reply With Quote
Old 02-29-2008, 09:40 AM   #3
6T7L71CPE
CF Senior Member
6T7L71CPE's Avatar
I've been using CHAMPION RN14YC. Which NGK's are you using or thinking about? Thanks
6T7L71CPE is offline   Reply With Quote
Old 03-01-2008, 04:46 AM   #4
babbah
CF Senior Member
babbah's Avatar
Shurshot - The NGK heat ranges are not reversed. Their hottest to coolest plug ranges are from 2 (HOT) to 11(Cold).
http://www.ngksparkplugs.com/docs/te...tnumberkey.pdf
7 is a very cold plug range that is commonly used in motorcycle engines. Most run 5's on the street.
Old 03-01-2008, 07:16 AM   #5
Shurshot
CF Senior Member
Are we talking NGK plugs as a whole or just their V series plugs...... seemed to me by your original post you were only speaking of the V series racing plugs that in the information made available to me start at a 7 for the coldest one .........that is borderline "to cold" for an 11:1 motor on the street..........
Old 03-01-2008, 04:38 PM   #6
babbah
CF Senior Member
babbah's Avatar
Hi Shur - I was inquiring about the Iridium IX plugs, not racing plugs. I wouldn't run racing plugs on a car that is street driven.
I have installed the Iridiums in my BB and there actually is a difference in perfomance...The motor idles about 100+ RPM faster now and it is a smooth as silk. Mine is a 11:1 BB with aluninum L88 closed chamber heads, a solid cam with 262@.050 duration, MSD ignition and modified tri-power carbs. I run 18 degrees initial advance and the cam loves it.
I have no pinging and motor shuts right off. I run 6 heatrange (Street plug)
I spoke to NGK before I bought them and they said that many racers are using the iridiums also.
Try em youll like em.....
Old 03-04-2008, 12:15 PM   #7
speedsk899
CF Senior Member
speedsk899's Avatar
Send a message via Yahoo to speedsk899
I have not tried them, but my tuner had a C5 come in with the iridiums in it. He dynoed it then put the regular NGK resister plug in it and gained 30rwhp......After hearing that I stayed with the resister plugs
speedsk899 is offline   Reply With Quote
Old 03-04-2008, 01:06 PM   #8
Shurshot
CF Senior Member
Quote:
Wow
And with no other changes or motor temperature differences?
Old 03-04-2008, 01:07 PM   #9
speedsk899
CF Senior Member
speedsk899's Avatar
Wow
All they did was change them out and dyno it again, same day.......They changed nothing else. I don't know if it was a fluke the first pull, but it was enough for me
Old 03-04-2008, 01:12 PM   #10
Shurshot
CF Senior Member
well that would certainly be enough for me too
When I get back together again I will try a comparison and post it.. However being as the guy with my heads is really dragging his feet it will not be for a few weeks
Old 05-11-2008, 08:27 AM   #11
1FASTVERT
CF Senior Member
Support Corvetteforum!
1FASTVERT's Avatar
I heard that they put in the performance hood seal and gained another 20rwhp. You just never know. Here's your sign.
1FASTVERT is offline   Reply With Quote
Old 05-12-2008, 11:02 AM   #12
gkull
CF Senior Member
gkull's Avatar
Quote:
I dyno motors at work. I have heard the same BS about Platinum plugs loosing hp. IMO - If the plug is the correct heat range, indexed the same, non resister, and gapped exactly the same, the tip material does not matter.
I use Bosch platinum 4 tip in a couple of my cars and Autolight plat in my racing vette
gkull is offline   Reply With Quote
Old 05-24-2008, 05:50 PM   #13
Shurshot
CF Senior Member
I finally got my motor running again and it is running much better now with the regular resistor plugs in it versus the R5671A-7 iridium that I used before. However I cannot say that the plug change gets the credit because there were some other changes done while I had it torn down. All I can do is after I get it installed is one day switch back to the irdium plugs and see if there is any difference.
I did not change the plugs for a HP gain but for part of the break in time for the rings to seat that would include some "easy driving" and because it used to run on the rich side . However while was I wondering on what change made it run so much better I remembered this thread
Doug
Reload this Page NGK Iridium Spark Plugs
Tags
2008, 2314, c6, corvette, iridium, ngk, plug, plugs, spark, sparkplugs, testimonial
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
