Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-07-2008, 07:18 PM   #1
arh
Junior Member
Default 383, 434 questions
i currently have a 383 with world sportsman II heads that has a mild cam(unknown grind) and is not very quick. the car is a 63 conv. with a 4 speed and 3.73 gears. my question is do i put in a solid roller and a set of afr heads on the 383 or build a 434 (i already have the block)and use my sportsman II heads. i am trying to stay within about a $3500 budget. which combo would make more power?
thanks,
adam
arh is offline   Reply With Quote
Old 02-09-2008, 11:23 AM   #2
gkull
CF Senior Member
gkull's Avatar
You need to maximize what you have with a good roller cam of around 236 intake. You also need something like a Weiand Stealth dual plane or their single plane. You need good headers and a free flowing dual exhaust system.
Then you can reuse all these parts if you ever decide to upgrade to a 400+ ci
gkull is offline   Reply With Quote
Old 02-09-2008, 11:51 AM   #3
arh
Junior Member
Default world heads
the world heads are 10+ years old with very low miles. is it worth the money to upgrade with newer heads? it has a victor jr. intake.
Old 02-09-2008, 11:59 AM   #4
BLOCKMAN
CF Senior Member
We have seen some good results using the big runner Vortec Bowtie heads.
BLOCKMAN is offline   Reply With Quote
Old 02-09-2008, 12:18 PM   #5
gkull
CF Senior Member
gkull's Avatar
Quote:
What is the max rpm you plan on spinning your motor? The SPII heads with a bigger cam and mid .500 lift can feed a 383 up to about 6000 rpm.
The VJ intake is a poor example. Without turtles installed and time on the flow bench it provides fuel separation........ It was intended for 4000-8000
Old 02-09-2008, 07:19 PM   #6
ironarms
CF Senior Member
St. Jude Donor '05-'08-'09
ironarms's Avatar
if you have side exhaust and go with the afr heads you will need custom headers as i have found that no one makes headers for the raised port heads and side exhaust, ( Stahl makes them custom)
ironarms is offline   Reply With Quote
Reload this Page 383, 434 questions
Tags
383, 8000, 8016, bench, c5, flow, forum, intake, mild, stealth, testing, weiand
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
DFI help on VE tables vs timing vs inj DC jerkyboy C4 Scan & Tune 16 08-20-2005 09:56 AM
Do I need to go to 30# injectors??? Strike3 C4 Tech/Performance 214 05-21-2005 02:51 AM
"My" conclusions with regards to SD vs MAF ski_dwn_it C4 Tech/Performance 66 09-07-2004 03:43 PM
383 or larger with Super ram and 219 cam questions LD85 C4 Tech/Performance 23 10-23-2003 10:56 AM
427 SBC Questions TeenagerWith74Vette Engine Mods 54 06-01-2002 04:36 AM
What can be done to an L98 block? scorp508 Engine Mods 12 02-16-2002 11:19 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
