Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-27-2008, 09:03 PM   #1
butterfly effect
Junior Member
Default carb jetting
I just fitted a zz383 gm performance engine. The carb that I used is a holly double pumper 4150 series pn 0-82751 , 750 . What jets and power valve should I start with? I also used their single plane intake.
butterfly effect is offline   Reply With Quote
Old 01-27-2008, 10:24 PM   #2
WWK888
CF Senior Member
WWK888's Avatar
You are in the wrong section, this is Help for problems with the forum, like posting pics etc...
WWK888 is offline   Reply With Quote
Old 03-26-2008, 01:50 AM   #3
BlackRocket
CF Senior Member
BlackRocket's Avatar
I have the same problem....383 with a Barry Grand 750 Mighty Demon. I know the engine is running rich so I will just get one of those jet kits from Summit or Jegs and start installing smaller ones until it runs right!
BlackRocket is offline   Reply With Quote
Old 03-26-2008, 04:14 AM   #4
babbah
CF Senior Member
babbah's Avatar
Quote:
babbah is offline   Reply With Quote
Old 03-26-2008, 05:10 AM   #5
WWK888
CF Senior Member
WWK888's Avatar
Quote:
Originally Posted by babbah View Post
Why are you rolling your eyes at me? When the op first posted this it was in the Help section (like in help with posting pictures etc...).
Obviously a mod moved this thread to the proper section after my suggestion.
Old 03-27-2008, 02:49 AM   #6
Curveit
CF Senior Member
Curveit's Avatar
Carb jetting is usually pretty close. Make changes 2 steps(jet sizes) at a time; 1 step probably wouldn't show enough difference to evaluate. After you figure if you need to go richer or smaller, you can fine tune to 1 jet size.
Curveit is offline   Reply With Quote
Old 03-27-2008, 10:54 AM   #7
gkull
CF Senior Member
gkull's Avatar
Quote:
Normally out of the box most carbs are somewhat close for a moderate engine at sea level. The holley web site just like the Demon web site has the base line settings.
the ZZ383 and a single plane would probably use a 6.5 PV. single planes need an instant squirter. So set the squirters for instant action.
gkull is online now   Reply With Quote
Reload this Page carb jetting
Tags
082751, 4150, 82751, carb, corvette, factory, forum, holley, jet, jetting, problems, reviews, size, sizes, zz383
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any problem with doing this??? ralph Engine Mods 15 09-30-2004 12:59 PM
Carb jetting? JoeRags C3 Tech/Performance 13 07-16-2004 01:55 PM
Carb Jetting Opinions... bence13_33 C3 Tech/Performance 12 07-05-2003 11:44 AM
Advantages of a Carb setup........ OrangeC4 C4 Tech/Performance 16 09-22-2002 06:39 AM
CorvetteForum Loaner Carb now available to Forum Members! lars C3 Tech/Performance 104 05-01-2002 06:55 PM
Best guess for Holley carb jetting - real answer tomorrow Maurice Engine Mods 18 04-08-2002 12:26 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
