I put this in the C3 Perf section but didnt get many replies... figure'd id try here
I am considering swapping out my stock ZZ4 heads for some AFRs and the HOTcam that I already installed for a Compcam...
I posted this setup a few years back, but no one ever seemed interested in it... its basically a stock zz4 bottom end with the AFRs and Compcam... I already have the single plane intake, 750 carb, and good exhaust...
I can see doing this setup for under $2500 myself. Doesnt seem bad to achieve 500+Hp IMO.
I have some questions tho as im no expert on building up a motor.
The stock ZZ4 heads are 58cc chambers, but the smallest you can get in a AFR is 65cc. I am presuming I would need to have the heads milled to retain my 10:1 compression ration? or how close would the ratio be running the 65cc and how much HP/TQ would i lose by not matching the 58cc? If I decide to mill the heads, is this something AFR can do from the factory and tack on the price? Or am I better off buying them from summit and having a shop mill them down?
This setup makes some serious power above 6000RPM and AFR recommends their higher rating springs and a "Hydra Rev Kit" IS this something I should definitely get? if so there are 2 different types, ones for factory lifters and one for aftermarket... im guessing the zz4s would be factory??
Here are the cam specs...
Part Number 08-444-8
Engine -Present Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR300HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.562 0.58
Duration At 0.006 Tappet Lift 300 306
Valve Timing At 0.006
Open Close
Intake 44 76
Exhaust 87 39
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 248 254
Lobe Lift 0.375 0.387
Lobe Separation 110
Lastly, is this somethign that I would be able to do on my own? Or have to have a shop do... I am definitely mechanically advanced... already did the HOTCAM, but with help of my father. Changed the intake a few times, but like I said am capable of working on things... if I do it, whats involved in doing the heads? im guessing its fairly simple bolting and unbolting them, and dropping in the other parts?? Also, when I did the cam last time, I dont remember using cam timing wheel... is it completely necessary.. if not, how should I approach that install??
Thanks in advance with all the questions!
Chris
Parts list
1 - Heads $~1400-1500 + milling?
2 - Springs - $108
3 - Hydra Rev Kit - $240
4 - Cam - $256
Im running a Tremec TKO 3.27:1 first gear trans, 3.55 gears, and use the car mostly for racing/hard street driving. Im thinking about 500HP will get me into the 11s Nat. Asp. if not close. Im running 12.8 @ 107 all day long with ~400HP
Quote:
Combo 102 is a GM ZZ4 350 cu. in. engine with AFR 195 heads and a Comp Cams hydraulic roller cam. With an 850 carb and 1 3/4 in. headers, this engine produces 506 HP and 436 ft-lbs of torque. This engine shows what that adequate induction and exhaust systems are imperative for more power. 3 in. mufflers could have helped a bit, though.
Displacement: 350 cu. in.
Carburetor: Demon 850
Heads: Air Flow Research 195, with 2.02/1.60 in. valves
Intake: Edelbrock Victor Jr.
Camshaft: Comp Cams hydraulic roller, with 0.562/0.580 in. of lift and 248/254° of duration @ 0.050 in. of lift.
Exhaust: Hooker 1 3/4 in. headers and 2 1/2 in. Flowmaster mufflers
Pistons: GM high-silicon aluminum
Rods: GM
Crank: GM forged
Ignition: MSD 6AL
Comp. Ratio: 10:1
MAX HP: 506 @ 6500
MAX Torque: 436 @ 5500
