best overall MODs for a 350 CFI injected C4
Old 02-01-2008, 06:44 PM
VIN_#_00521__Z-51_C4
VIN_#_00521__Z-51_C4's Avatar
Default best overall MODs for a 350 CFI injected C4
I have been around about simple mods for an '84 CFI C4... What are the best mods to go with...(I'm not looking for insane HP increases just something that can get me past 250hp- 265hp.....At this time My C4 is still running fine, with the exception of the valve cover leaking a little oil and a by-passed switch for the elec fan....with 154k....how long she will go before the engine dies on me ... should i wait or REBUILD NOW ... ?
.. Im going with 1.6 to 1 (3/8 stud ) Roller-tip rockers, possibly get a powermax 2040 cam and hardened pushrods.. 170cc heads....( Is there anything I can do with the stock heads.. I know they are JUNK but for a budget..What can be done with them..?.) Change the valves , springs rods rockers Can the stock heads be ported at all or are they crap and should be replaced.....
....What are the best ones for a reasonable price (remember that this C4 has 154,000 on the clock so.)...when I replace the rockers to roller-tip rockers, Should i replace the springs as well..should i change them to a different size.. and when it comes to a rebuild (Im new to that game as well )
... list your best ideas / mods you can come up with .... and imagine you were on a tight budget but want to build this car up....
Old 02-11-2008, 03:37 PM
BUMP C'mon C4 CFI Guys Step up help me out here Motors out of the car and im starting the tear-down of the engine
Old 02-12-2008, 11:21 AM
CFI-EFI
CFI-EFI's Avatar
I have the feeling of deja vu. Haven't I answered these same questions for you in the past?
In your first post, here, you ask:
Then you follow up with:
It sounds as though the decision to overhaul has been made. There was no reason to pull the engine to make those modifications. In your opening post, what does, "I have been around about simple mods for an '84 CFI C4...", mean? The modifications you have planned sound reasonable, however the single, very most important, modification to make is to port your intake manifold. All of your time and money will be wasted if to try to run with your unported stock manifold.
Your sig:
1984 Corvette C4 (RPO-Z51) --1 of 2,430 Gold C4s...
Only 3,729 1984 C4s w/ RPO Z51
Your sig contains a few errors. Rather than "1 of 2,430 Gold C4s", it should read 1 of 2,430 Gold 1984 C4s. There were 2430 gold 1984s. I'm sure there were gold Corvettes built in the remaining 12 years of C4 production. Also, there were 25,995, Z51 optioned cars in 1984. Fully half the '84 production run of 51,547 were Z51 cars, hardly a rarity. "Only 3,729 1984 C4s w/ RPO Z51" is seriously in error.
RACE ON!!!
Old 05-20-2008, 10:36 PM
Steve20
Steve20's Avatar
you should see this dude's history-lies like a rug. I don't think he would know how to add oil never mind pulling motor-hopeless
Old 06-20-2008, 03:34 PM
Well Genius Enlighten all of us ON MY HISTORY Explain in detail what is a lie and what Isn't You sound like a real Jerk to me
whatever is in my sig was what i looked up, Big F'k deal if one number is wrong ( I think they refer to that as a typo or a mistake )
Quit your pissing and moaning and GET OFF MY BACK !
Be a mand and Help me out
Don't be a JERK !
Old 06-30-2008, 07:37 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I'm sure that you'll get some good help now! lol.
Old 07-16-2008, 09:17 PM
nate23
nate23's Avatar
easy: Timing @12, Port the intake, headers, true dual exhaust without cats (screw algore), 1.6:1 roller rockers, 85 fuel pump, better oil, fuel pressure at about 14 PSI
Less easy: Aluminum heads, cam, roller rockers, megasqirt, higher gears, torque converter
less easy still: 383
less cheap: 427
psychotic: 502, blower, hole in hood.
Old 08-16-2008, 12:51 AM
KLLRVET
KLLRVET's Avatar
Just put an Ls1 in it and call it a day
To best overall MODs for a 350 CFI injected C4
Quick Reply: best overall MODs for a 350 CFI injected C4
