Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-21-2007, 02:49 PM   #1
korvetkeith
CF Senior Member
korvetkeith's Avatar
Send a message via AIM to korvetkeith
Default Damper questions, SFI approved?
Well I installed my 350 vortec truck motor with the stock damper. It's an 8" damper and turns out it hits the cross member in my '84, doh.
Anyways I was wonder if anyone could recommend a damper for me, it is a stock '97 vortec 350 9.4 to 1 with a 218/224 roller with 1.6rr's and conical valve springs.
Is SFI approval necessary for tech at the track? I'm pretty sure it's not, but I'm just wondering what the approval means.
Can I get away with a cheapy or the stock one off of my '84?
Thanks,
Keith
korvetkeith is offline   Reply With Quote
Old 02-22-2007, 11:27 AM   #2
C4Techie
CF Senior Member
C4Techie's Avatar
Use the one off the '84. SFI has safety specs for a wide variety of racing equipment. Per NHRA rules, you don't need a SFI approved damper unless you will be dipping into the 10s at the strip. Make sure that the damper marking and the timing tab are compatible, or you may have trouble setting the timing.
C4Techie is offline   Reply With Quote
Reload this Page Damper questions, SFI approved?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
