Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-20-2007, 10:39 AM   #1
mrc24x
CF Senior Member
mrc24x's Avatar
Default Opinions needed on new build please..(L98/TPI)
I'm about to pull the trigger and I just want to double check w/ the braintrust on the forum. I've been trying to learn as much as possible by searching and lurking but here goes.....
**FWIW-I'm limited to 355 w/ 10:1 cr max, and I must use the stock head and intake castings for vintage races. TPIS ported 113's w/ TPIS runners , Extrude honed base and plenum.
Option 1-
Eagle ESP-435335005700 4340 3.48" Crank ...$499
Scat 2-ICR6125-7/16 6.125" 4340 w/7/16 arp...$259
Mahle Power Pak Forged MLE-SBC125030I16 ...$559
4.03", -16cc dish, 1.125 CH, 410 grams, pin=118g
My math:58cc chamber, 16cc dish,4.030 bore, deck block to 9.010" w/ .021 gasket (4.1"bore)= .041 quench w/ ~9.7 CR depending on the online calculator used.
Option 2-
Same Crank above....
Scat 2-ICR6000-7/16 rods (same as above but 6")
Manley 4.030" ,-14.5cc dished F1, 1.250CH, 454grams
including pin! ...$625 + rings.
Same math as above ends up just under 10:1 at 9.96:1 w/ the 14.5 dish.
Sorry this is long but any input will be appreciated. Quality of components??, Is my math in the ballpark??, Price?? Is it overkill for 5800 rpm / 320 rwhp??
Thanks in advance,
Matt
mrc24x is online now   Reply With Quote
Old 02-20-2007, 11:56 AM   #2
knight37128
CF Senior Member
knight37128's Avatar
I would go with the longer rod.
knight37128 is offline   Reply With Quote
Old 02-22-2007, 02:05 AM   #3
Deakins
CF Senior Member
I would go with the longer rod and would look into some lightweight components. The weight seems to really hurt a engine that is limited as much as this so if money is not too tight I would find a very good lightweight crankshaft with a Honda rod journal and get a set of ultra light connecting rods to match. This will yield the most power out of that combination. Just my thoughts and as always; the competitiveness and budget tend to determine how far to go with these engines.
Deakins is offline   Reply With Quote
Old 02-23-2007, 01:01 PM   #4
mrc24x
CF Senior Member
mrc24x's Avatar
Thanks guys,
It looks like option 1 is the preferred choice so I'm getting closer. Now the only change is I am going with the scat 4340 crank (51 lb) instead of Eagle.
Deakin, I agree about the LW crank but it's hard to find 1pc cranks in my budget. I decided to spend a little more for lw pistons vs lw crank based on some of the books I have been reading. Ohio Crank has a 43 lb crank for $550 but it is for a 2pc seal. Oh well. I'm also llimited to around 325 rwhp (8.9 lb per HP w/ me) so hopefully this package will get me close.
Thanks for the input. Is it me or is sloooow around here??
Old 02-23-2007, 01:32 PM   #5
Deakins
CF Senior Member
It's slow!
Old 02-28-2007, 06:08 PM   #6
comp
CF Senior Member
comp's Avatar
what did you decide on ?
comp is offline   Reply With Quote
Reload this Page Opinions needed on new build please..(L98/TPI)
Tags
2icr6000, build, c3, corvette, engine, injection, l98, modify, mods, nitrous, opinions, port, tpi, tuned
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
