Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2007, 05:30 PM   #1
blackinfoline
CF Senior Member
Default Why is my C5 engine cutting off
Has anyone had the problem with their C5 engine cutting off after starting. I start the engine and put in drive and it cut off about four or five times. The problems is not consistent it does it every now and then but when it does, three or four times cut off.
blackinfoline is offline   Reply With Quote
Old 02-15-2007, 11:08 PM   #2
zo6vetteman2003
CF Senior Member
zo6vetteman2003's Avatar
Send a message via Yahoo to zo6vetteman2003
Quote:
This sounds like a problem with the VATS (VEHICLE ANTI-THEFT SYSTEM) cutting off fuel to the fuel injectors. It is also possible that this could be related to your pass key resistor pellet or ignition cylinder. The ignition reads your key's pellet. Sometimes the cylinder gets worn and will not read the key anymore. Try using your spare key and see if this still happens. If you want information on by-passing the VATS, I'll tell you how to do it for under $10.00 in parts.
__________________
2003 EB ZO6: Vararam Widemouth, Carbon Fiber Powerduct, FAST LSX 90mm Intake, Ported and polished 90mm LS2 throttlebody, 36# Fuel Injectors, Ported and polished 59cc LS6 Stage II heads, Crane 1.8 Gold Race rockers. Comp XR281HR (228/230 Dura.) (.606/.608 I/E lift) 112 degree lsa. Kooks 1-7/8" LT's 3" X pipe, Borla Stingers Tuning by "Slowhawk" DEZ Racing Seekonk Ma. New SPEC Stage 3+ Nitto 555RII - Rear 305/35/18's Front 275/40/17's
1999 Stock Magnetic Red Coupe 30K miles
zo6vetteman2003 is offline   Reply With Quote
Reload this Page Why is my C5 engine cutting off
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
Ummm... REMOVED my PCV oil mod........ YO-EL C5 Tech 172 07-08-2003 10:56 AM
No faith in Tuner UAWDES1 C5 Scan & Tune 34 12-11-2002 06:03 AM
HYDROLOCKED!!! vetteshop C5 Tech 32 09-19-2001 09:32 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
