Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-10-2007, 09:56 PM   #1
sdonnelly
CF Senior Member
sdonnelly's Avatar
Default Best head
I have three sets of stock iron heads for a 350. Is it possible to tell which set, if any, would be the best ones to use by the casting numbers on the heads or do these numbers not reveal all the info needed to make that decision? If the numbers do provide enough info, could anyone tell me where I could get the info to decipher them? Thanks
sdonnelly is offline   Reply With Quote
Old 02-10-2007, 10:12 PM   #2
JackDidley
CF Senior Member
JackDidley's Avatar
Try this.
http://www.mortec.com/castnum.htm
JackDidley is offline   Reply With Quote
Old 02-10-2007, 10:17 PM   #3
JackDidley
CF Senior Member
JackDidley's Avatar
Another.http://purplesagetradingpost.com/sum...ightning%20180
Old 02-10-2007, 10:30 PM   #4
sdonnelly
CF Senior Member
sdonnelly's Avatar
Thanks. I tried that first one earlier but it went somewhere else. Your link worked.
I have two sets that are 333882 which it just says, 76cc chambers.
The other set is 462624 which says, 76cc chambers 2.02/1.6 valves. It shows several valves sizes for that number but I know this set is that size. The 333882 set I have on now need valve seals as it's pretty blue behind the car when I start it. The 462624 heads are like new. Would it be worth the trouble to change to those heads or just put new seals on the current ones?
If it matters, I have a 350 4bolt from a '74 pickup in it. 35,000 miles on it, currently xe256 cam with tunnel ram and twin 450 carbs. I have a xe268 cam on the way, and a set of headers to go on. Also have a 2400 stall convertor to put in. Dual 2 1/2 exhaust, don't know the gear size. So when I'm doing all that should I swap heads as well?
I know none of these are anything too great, I'd just like to use the best ones I have.
Old 02-11-2007, 09:04 AM   #5
Corvette Kid
Redneck Renaissance Man
St. Jude Donor '04-'05-'06-'07
Support Corvetteforum!
Corvette Kid's Avatar
Location: Error 503 Service Unavailable Guru Meditation, CFOT
Quote:
Originally Posted by Spankyellow View Post
Excellent sites, Spank! Saved.
Corvette Kid is offline   Reply With Quote
Reload this Page Best head
Tags
462624, heads, sbc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best head unit Son93SL2 Audio/Electronics 20 01-18-2010 01:54 PM
best head & cam package 108C6 C5 Tech 11 08-11-2005 02:30 AM
Best head and cam package for you rmoney. AbadVette C5 Tech 22 12-23-2003 11:26 AM
Whos got the best Head Epyon127 C4 Tech/Performance 9 05-19-2003 11:25 PM
Who does the best Head? UKPaul C3 Tech/Performance 15 08-05-2002 09:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
