I've tried doing an advanced search on 4/7 Cam and keep coming up with nothing specific to cams where the firing order is changed from 18436572 to 18736542.
Can anyone give me or point me to the archived threads that explain in laymen's terms the benefits of running cams that swap the firing order of the #4 and #7? Is there an advantage for a street driven motor to do this?
'65 Vert, 2-tops, Sweet Thunder side exhausts, 327/300 now has a "mule motor" 327 dressed as a 365 Horse with '461 Iron Heads (2.02/1.6's), 3.70 Posi, M-20, power nuthin'-'cept antenna AND Classic Auto Air, owned 30 years, on the road 12...smilin' all the time!!
Well i think i read something in the Chevy Pwr Manual or maybe D. Vizards "How to Build HP part I" on this swap but don't have those books right now. This 4/7 swap is catching on as all the major cam mfrs are selling them. Haven't read of any "before then after" results testing though.
Let us know what u find and any result u get.
cardo0
__________________
74 T-top, L-48, 4spd, A/C, narly blue. Goodwrench 350 underwent new heads (SR Torquers), Schneider solid cam and Thorley headers due to domino effect of broken motor mount >broken fan shroud>remove radiator & A/C package. Now runs a Performer Air Gap with a lars majic chokeless Qjet on top. Also Street dampner, MSD dist, 6AL and Baster II. http://members.cardomain.com/cardo0
Thanks for the response. Guess there's a lot more questions then answers that pop up regarding this swap. Would like to get real world experience/feedback from those out here who may have done this. Kind'a think this swap is more for the full race sector and not a street application.
Thanks again and I've got to do some more reading up.
Well it started in the full race sector and has not come on like everyone though it would. The main reason is that they do not show much of an increase in hp on an engine dyno so most street guys don't see the point of changing over. The main reason we run them in our fast street cars and race cars is that they do seem to have a much better idle and run overall much smoother. So we feel that they do really help longevity and street manners; but the power is limited to the grind like on all other cams.
I purchased the 4-7 swap custom billet roller for my 427 SB. I'm always ready to try new things like that. I also use thermal coatings for the pistons and chambers. Every little edge can make a great difference.
I saw the show...On another forum I visit; with some well respected engine builders, don't buy the results showed on the program. I've read it's only a few HP more. I personally don't know.
I had heard/read about 7-15 HP depending on the combo.
I have run single plane exclusivly(SP?) since the 80's in my Vette. On many tear downs, you can see the inequality of fuel distribution/heat per cylinder. After talking to ....................... I even tried staggerd jetting in the primaries............
I came to the conclusion that without sequential FI with 8 tube monitering you are never going to get it right. FAST electronics for $3500 and Sheet metal intakes are the closest we can come to perfect. Your never going to compete with altered cam timing for the outer 4 cylinders like NASCAR has done.
I don't have the resources for dyno time on any little mod
There was an article in CHP on this. They did the swap on the same motor and dynoed it. The result was that the current firing order actually made slightly more power. I'm talking so slight, they were almost identical in comparison on the dyno sheet. This all originated as a engine building secret among NASCAR teams, doing a 4/7 swap would add more power.
__________________
2003 EB ZO6: Vararam Widemouth, Carbon Fiber Powerduct, FAST LSX 90mm Intake, Ported and polished 90mm LS2 throttlebody, 36# Fuel Injectors, Ported and polished 59cc LS6 Stage II heads, Crane 1.8 Gold Race rockers. Comp XR281HR (228/230 Dura.) (.606/.608 I/E lift) 112 degree lsa. Kooks 1-7/8" LT's 3" X pipe, Borla Stingers Tuning by "Slowhawk" DEZ Racing Seekonk Ma. New SPEC Stage 3+ Nitto 555RII - Rear 305/35/18's Front 275/40/17's
1999 Stock Magnetic Red Coupe 30K miles
One of the other benefits besides slight icrease in hp of the 4/7 swap comes into play with bigger stroke combo's. With standard firing order 18436572 you have 3 hits in order over the #4 main being 657, with the 4/7 18736542 its more evenly distibuted and easier on the mains.
With the revised firing order, fuel distribution dilemmas are resolved.
The engine tends to run cooler, and perhaps just as important, the
engine is actually smoother. How much extra power is there? Anywhere
between 8 to 10 measurable horsepower.
C4 Tech had some entertainment from the topic in a couple of threads
Not much came out of this one unless you count picturing guys
sitting at PCs making rumpity-rump-rump-rump noises.
