Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2007, 02:25 PM   #1
hosspowerinc
CF Senior Member
hosspowerinc's Avatar
Default Vortec Heads Question: 906 casting or not???
I am going to get a set of Vortecs to go on my 406 build and I have a question. Everyone says stay away from the 906 castings because of the exhaust valve. Im just trying to figure out what exactly is wrong with it and what needs to be done to correct it? Ive heard that the seat is thicker but couldnt you just do a bowl blend and smooth it out? Interested in what you guys have to say
hosspowerinc is offline   Reply With Quote
Old 02-11-2007, 10:01 AM   #2
BLOCKMAN
CF Senior Member
Quote:
We build a lot of circle track engines with the 906 casting and so far have never had any issues and when we have time in the shop we build a few 383's with the 906 castings and no issues so far.
The newer mexican castings have smaller intake runners then the older 906 castings and the non Mexican 062 Vortec casting are a good choice as well.
And on all the heads we machine we always bowl blend the intake and exhaust with bowl hog.
BLOCKMAN is offline   Reply With Quote
Old 02-26-2007, 01:57 AM   #3
KyleDallas
CF Senior Member
KyleDallas's Avatar
I've heard the 906's aren't as easy to port as the 062's...and that the
exhaust side port was the problem when trying to mod for increased flow.
I have no idea what budget you are working with... you can pick up a
used set of 062's on Ebay for $300 complete....
But for $550 to $650 you can get a pair of Bowtie Vortecs or Dart
Platinums...and make 30 to 80 more horespower.....your big cube motor
would respond very well to either the Bowties or the Platinums..
we're only talking about $200 to $350 more dollars.... not much money
for the extra power.
the Platinums on that engine would make a 500hp plus combo with the right cam..
KyleDallas is offline   Reply With Quote
Old 02-28-2007, 06:06 PM   #4
comp
CF Senior Member
comp's Avatar
comp is offline   Reply With Quote
Old 03-05-2007, 08:38 PM   #5
toupstrio
CF Senior Member
Support Corvetteforum!
toupstrio's Avatar
What about the steam holes for a 406 build? Do vortec's have them?
toupstrio is offline   Reply With Quote
Old 03-05-2007, 10:30 PM   #6
hosspowerinc
CF Senior Member
They have to be drilled but you can do it at home using a 400 head gasket as a template.
Old 03-06-2007, 05:16 PM   #7
toupstrio
CF Senior Member
toupstrio's Avatar
I did not know that, thats cool I have a 400 and a set of vortec heads thanks for the update.
Old 03-06-2007, 06:59 PM   #8
hosspowerinc
CF Senior Member
You might be interested in this build then. Its what Im building for my vette. Lots of power for very little $.
http://www.chevyhiperformance.com/te..._block_torque/
Old 03-06-2007, 08:36 PM   #9
comp
CF Senior Member
comp's Avatar
Old 03-08-2007, 01:08 PM   #10
Mike_B
CF Member
Seems like some of the 906 castings used for heavy-duty truck engines had a beefier, but restrictive exhaust valve seat (or more material underneath the seat?). If you order a new set from someone like Scoggin Dickey, you will get the more common casting.
Depending on what you expect from that 406, I think the 906 port volumes are too small, and your valve lift will be limited without machine work. If you're set on Vortecs, have you looked a the GM Bowtie Vortecs or Edlebrock E-Tec?
Mike_B is offline   Reply With Quote
Old 03-08-2007, 03:35 PM   #11
hosspowerinc
CF Senior Member
Quote:
Geeze how many times to I have to say this. THE PORTS ARE THE SAME ON BOTH CASTINGS. The seat is the only difference.
Reload this Page Vortec Heads Question: 906 casting or not???
Tags
062, 906, blend, casting, drilled, exhaust, good, head, heads, holes, make, mexican, performance, stem, vortec, vortecheadsebay, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
