Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2007, 10:36 PM   #1
63FI
CF Senior Member
Default Lightweight and ultra light Crankshafts
I'm doing a few motors, both destroked 400 small blocks, and was just wondering what power increase or performance difference I might see (other than it might wind up a little quicker) One crank is a crower ultra for a 353 which weighs 38 lbs and the other for a 377 which weighs 48 lbs.
63FI is offline   Reply With Quote
Old 01-24-2007, 10:56 PM   #2
BLOCKMAN
CF Senior Member
We build some of our circle track engines with 283 mains and Honda journals and when they are all balanced they weigh about 31 pounds and the with the light weight rods and pistons and pins the bob weight are around the high 1300's and the drivers say they feel like that have 600 foot pounds of torque.
You figue when one cylinder fires it has to move 7 other rods and pistons and crank and now use light weight parts and you should also see a power gain as well as quickness.
BLOCKMAN is offline   Reply With Quote
Old 01-25-2007, 02:39 PM   #3
comp
CF Senior Member
comp's Avatar
what brand are you using ?
comp is offline   Reply With Quote
Old 01-25-2007, 04:11 PM   #4
jimvette999
CF Senior Member
jimvette999's Avatar
Kerry at Crower told me Ultra Light was no longer avail....I had to go to Callies. Check out their Magnum XL. It's about $1400 more than their other light crank the Magnum so I went with that. Art at Callies takes the time to talk to you unlike Kerry @ Crower fwiw. Art said they sell the XL's to the circle track guys that want the quick revs out of the corners. He didn't mention horsepower increases but it stands to reason that there is some to be gained.
http://www.callies.com/crankshafts/magnumxl1.htm
Jim
jimvette999 is offline   Reply With Quote
Old 01-26-2007, 12:15 AM   #5
BLOCKMAN
CF Senior Member
Quote:
Rick from King's Crankshaft Co. in NC builds all our custom cranks 1-704-483-1005.
Old 01-26-2007, 01:51 PM   #6
gkull
CF Senior Member
gkull's Avatar
Quote:
I purchased the Motown 4.125 bore block with 350 mains to save weight. My present crank (4.00 stroker) is 42 pounds with pendulum cut throws.
It's not just the crank. It is the total rotating assembly. You also need lighter, smaller diameter damper and light weight flywheel/clutch assembly
gkull is offline   Reply With Quote
Reload this Page Lightweight and ultra light Crankshafts
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
