Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2007, 12:08 PM   #1
international blue
CF Senior Member
international blue's Avatar
Default 427 switching closed cc to Open Pitfalls?
Has anyone switched closed chamber to open chamber heads on the 427 and had problems. Is the cyl OK with the closed chamber pistons?
JOE
international blue is offline   Reply With Quote
Old 01-23-2007, 12:30 PM   #2
C4Techie
CF Senior Member
C4Techie's Avatar
Yes. That is fine, but you'll have a drastic reduction in your compression ratio. Going the other way, chances are the bigger domed pistons would hit the closed chamber heads.
C4Techie is offline   Reply With Quote
Old 01-23-2007, 02:18 PM   #3
rklessdriver
CF Senior Member
rklessdriver's Avatar
Other than the reduced compression ratio, there are no problems.
Will
rklessdriver is offline   Reply With Quote
Old 02-19-2007, 11:00 PM   #4
TimAT
CF Senior Member
TimAT's Avatar
Open chamber pistons WILL hit closed chamber heads. depending on which closed chamber pistons and heads you use compression can end up anywhere from low to very low 9.5 to 7. There are so many different combinations of pistons and chamber sizes you'd have to know some of the variable stuff to even guess.
TimAT is offline   Reply With Quote
Reload this Page 427 switching closed cc to Open Pitfalls?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
