Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-22-2007, 11:57 AM   #1
big_G
CF Senior Member
big_G's Avatar
Default Solid roller Question
In an effort to increase reliability and longevity, I am replacing my conventional solid rollers with "Endure-X" style, being this is mostly street-driven. Should I use oil-feed restrictors in this application? TIA
__________________
Honey, I don't know how those black marks got on the driveway!
big_G is online now   Reply With Quote
Old 01-23-2007, 11:17 AM   #2
cuisinartvette
CF Senior Member
St. Jude Donor '05
Boy, thats a debatable topic!! I would talk to Comp....Personally Im using them in my solid roller motor, others say not to.
cuisinartvette is online now   Reply With Quote
Old 01-23-2007, 09:33 PM   #3
danno85
CF Senior Member
Quote:
No, because the reason roller lifters fail pre-maturely in a street engine is because the rollers overheat, and the additional oiling helps to cool them. You don't want to add oiling by switching to lifter bodies with the oil groove in them, and then turn around and put restrictors in place farther back in the pipeline - you'd be defeating the purpose.
BTW, I ran the early version of the Endure-X lifter for 22k miles with no problem.
Dan
danno85 is offline   Reply With Quote
Old 01-23-2007, 10:30 PM   #4
big_G
CF Senior Member
big_G's Avatar
Thanks, Dan
Old 01-28-2007, 07:26 PM   #5
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Mississauga, Ontario I know all the answers it's the questions I don't understand
I agree with lifter with priority oiling to the rollers I wouldn't use the restrictors, I use restrictors with the older style CC 818's that had no oiling to the rollers, 25,000 street miles so far, I just replaced one lifter about 500 clicks ago for brinneling of the bearings in the roller, the others are still going strong
Always remember not to let it idle too long when running a solid roller on the street, give it few shots of gas every few seconds, always gets the guy beside you going too at a light
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage
MotorHead is offline   Reply With Quote
Old 01-29-2007, 12:59 AM   #6
ZL1powr
CF Senior Member
ZL1powr's Avatar
I got ~40,000 miles out of the old stye Endur-X lifters before one started to fail. I replaced all the lifters with the newer re-buildable style Endur-X. I have not run oil-feed restrictors. It seems like that would defeet the pressurized oiling of the rollers with the Endur-X lifters.
__________________
1971, 565 cu in, Brodix Aluminum block, Ported Victor Jr intake, Dart 335 CNC Pro 1 heads, Custom solid roller cam (2-3, 4-7 swap fire), J&E pistons, Eagle 4340 H-beam rods, Eagle 4.25" 4340 crank, 950 DP carb, TKO-600, Tom's 12 bolt 3.73, . Daily driver.
Best Engine Dyno Run My Rides Drag Video with old engine 565 chasis dyno video Blown 65 sound clip
ZL1powr is offline   Reply With Quote
Old 02-03-2007, 11:13 PM   #7
Ironcross
CF Senior Member
Ironcross's Avatar
As a solid lifter engine it should be capable of 7K++ or it`s not worth it`s salt. Therefore the valve springs are very critical as the roller must follow the cam profile and not be bouncing at high rpm. In conjunction with the valve springs a rev kit is also a wise choice to help prevent the same issue. Unfortunately the lifters are heavy so they must be held to the cam and the rev kit does just that.
Ironcross is offline   Reply With Quote
Reload this Page Solid roller Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Solid Roller Spring Life VETDRMS C3 Tech/Performance 12 05-04-2005 01:26 PM
Solid Roller cam advice. FRC2000 Engine Mods 18 01-30-2003 10:04 PM
Help me decide about going balls out with a solid roller for my 427 MTI ironblock. Mopar Jimmy C5 Tech 28 12-30-2002 12:47 AM
LG Motorsports 418 Solid Roller is in rfgoss1 C5 Tech 44 10-05-2002 12:09 AM
Solid Roller cam recommendation for an LT4? lcvette C4 Tech/Performance 12 09-05-2001 12:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
