Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-08-2007, 01:54 AM   #1
MarkBychowski
CF Senior Member
MarkBychowski's Avatar
Default Max Rod length for 3.625 stroke?
I'm trying to decide on rods for my 3.625" (Cola) crank. It's made for 6" rods. I was also toying around with using a 6.125 rod, but after looking at the numbers it looks like that would only leave me with 1.0875" for the piston (as opposed to 1.2125" with the 6" rod). Assuming standard deck height.
The motor will strictly be NA, but even so, my assumption is the 6.125 rod is just not going to leave enough room.
Thoughts?
Thanks!
__________________
'96 LT4 Coupe
370CI, 4-stage dry sump w/ oil cooler, Willwood GN3 / GS calipers, High-vol MC, Adj Prop Valve, Poly bushings, Griffin Radiator, 58mm TB, EM Longtubes, Corsa Cat-back, Hardbar harness bar, B&M Ripper, Fidanza aluminum fw, Carolina stage 3 clutch, 3.73 gears, ATI Balancer, Relocated battery, Delteq ignition, Wideband O2, Autotap, LT1 edit, Ultrashield Race Seats
MarkBychowski is offline   Reply With Quote
Old 01-08-2007, 09:55 AM   #2
danno85
CF Senior Member
You can get pistons with a pin height as short as 1.000 inch, however the wrist pin is well up into the oil ring groove at that point and you have to run oil ring support rails. I'm not saying that's a bad thing, just making the point. The pistons for my latest combo have a 1.180 inch pin height and the pin does not intersect the oil ring groove. Personally, I would go with the 6 inch rod in your case and don't get too hung up on making the rod as long as possible. I know of one engine builder in particular who has won the Engine Masters challenge more than once that is a fan of short rods, and I know of sprint car guys running 4 inch stroke cranks with 5.850 length rods.
Have fun!
Dan
danno85 is online now   Reply With Quote
Old 01-09-2007, 06:14 PM   #3
MarkBychowski
CF Senior Member
Appreciate the advice -- I'll stick with the 6.0" rods
Thanks!
Old 01-09-2007, 08:41 PM   #4
Cris
CF Senior Member
Mark:
You will find that most aftermarket (catalog) piston pin heights are designed to match up with a 9.000" deck height. Someone must have decided a 9.000" deck insures that a stock block can be cleaned up to get the decks square and parallel.
Cris is offline   Reply With Quote
Old 01-09-2007, 11:34 PM   #5
MarkBychowski
CF Senior Member
Thanks -- good to know!
Old 01-10-2007, 05:14 PM   #6
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
I have that size stroke and went with 6.0" rods
__________________
Mike
Modified 1974 Corvette
388 big bore/ short stroke Dart SBC, TT II's, 4pt rollbar, Tremec TKO
Visit My Website
SmokedTires is offline   Reply With Quote
Old 01-11-2007, 02:56 AM   #7
MarkBychowski
CF Senior Member
Smoked, I checked out your site. You've got a damn nice car and an amazing motor!
Old 01-11-2007, 11:15 AM   #8
SmokedTires
CF Senior Member
St. Jude Donor '05
Thanks Mark
__________________
Mike
Visit My Website
Old 01-11-2007, 04:11 PM   #9
gkull
CF Senior Member
gkull's Avatar
Thoughts?
Thanks!
I was just out on the Wiseco piston site and they have a 1.060 pin to top piston for 6.125 rod and 3.625 stroke.
All of my 6 inch rod 3.750, 3.875, and my 4 inch stroker motors have had the pins behind the oil scraper ring. I do not run anything behind the ring.
gkull is offline   Reply With Quote
Old 01-13-2007, 02:04 AM   #10
Deakins
CF Senior Member
There is no problem with running the 1 inch pin height. We have built most of our engines with pins that are well into the oil groove and have never had a problem. We have had good results using the longer connecting rods and feel that this is the way to go. Just a note, the sprint car engines mentioned above that are running stroker cranks and 5.850 rods are probably doing so out of necessity due to deck height limitations. They simply can not fit anything else in a stock deck height block even with the 1 inch pin height; that doesn't mean that this the best way to go by any means! Sometimes you have to do what you have to do and in many cases a $5000 aluminum tall deck block is not an option for anyone other than a sponsored racer!
Deakins is offline   Reply With Quote
Old 01-13-2007, 11:51 PM   #11
MarkBychowski
CF Senior Member
Quote:
Thanks for the info, Deakins. Since my motor will be 1/2 street, 1/2 roadrace, I'm concerned about longevity / endurance of the bottom-end. Do you see any additional issues with long-term reliability or ring oiling? I'm not expecting to get 100K or anything like that out of it, but don't want to have to freshen it every year or two either.
Thanks!
Old 01-15-2007, 10:22 PM   #12
Deakins
CF Senior Member
Not at all! One thing to mention about this choice is that I am currently unaware of a 1 inch pin height piston that is anything but forged. Now for an engine that has a very high piston speeds or massive amounts of pressure and heat, the 500-1200$ spent here is necessary. With the shorter rod you may be able to find an off the shelf hypereutectic piston that will fit. This does two things; first it lowers the cost, but secondly (and more important) is that these pistons are fit up at a much tighter piston to wall clearance. This equates to less piston rock, no cold start knock or oil consumption, and just better overall street longevity. If your application does not need the durability offered by the forged piston you may think about running a set of hypereutectics. Most guys will argue that point saying they are a problem waiting to happen but we have yet to have a failure! With that said, the all aluminum full competition engine we run has and never will see a set of these; it all depends on the environment the engine will live in and the load that it imposes on it's parts.
Old 01-16-2007, 11:54 PM   #13
MarkBychowski
CF Senior Member
Thanks again! To be honest, I assumed I was going to go with forged pistons to be safe (although, not absolutely necessary for my combo). I want to be able to run it up to maybe 7200 or so max, but normally under 7000. I just want a margin of safety when I'm in the middle of a turn and need to hold it in gear a little longer.
At least now I know I have some options to work with.
Thanks again, all for your help!
Old 01-17-2007, 02:34 AM   #14
Deakins
CF Senior Member
Hey that's what I'm here for! If you have any other questions just post em or pm me and I may have some ideas that help. Good luck with the build.
Old 01-17-2007, 01:11 PM   #15
gkull
CF Senior Member
gkull's Avatar
Wrong You may think about running a set of hypereutectics.
I had a set of KB hypereutectics have a melt down and smear the aluminum into the ring lands. This was with a 3.48 stroke and never really run over 7200 rpm.
I called KB up and ask what was up with their pistons. They explained to me that Hyper pistons have FPM limitations (About 7000 rpm with a 3.48 stroke) Never again because the motor was trashed.
If your planning 7000 rpm with 1/16th inch racing rings. Figure about 10,000 miles and your going to start seeing light blue smoke. Leak down tests will show ring leak. They really need a rebuild by 15K.
Old 01-17-2007, 03:05 PM   #16
Cris
CF Senior Member
You will find forged pistons made from two different alloys. One is 4032 and one is 2618. The 4032 alloy has a higher concentration of silicon and this will reduce the thermal expansion. 4032 forged pistons can use pretty tight fits and you can avoid the dreaded piston knock. A good example are the Mahle pistons, their gaps are approaching the hypereutectics.
You don't get something for nothing, the 4032 alloy is not as strong (ductile) as the 2618. So in all-out applications, 2618 may be a better choice.
Reload this Page Max Rod length for 3.625 stroke?
Tags
348, 3625, 3750, 3875, cola, crank, crankshaft, forum, length, ls1, lt1, pistons, rod, sbc, stroke
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What would be your Ultimate Dream Small Block? John Dirks C3 Tech/Performance 23 09-10-2001 11:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
