Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-30-2006, 05:12 PM   #1
Surfer69
CF Senior Member
Surfer69's Avatar
Default Can you flip this head gasket?
I posted on tech but will try here. I installed the Victor Reinz 5746 head gasket but noticed it's partly covering the oil dipstick hole. There is no markings on the gasket like "this side up" so I'm wondering if I can flip the gasket? It seems to have a "nice shiny" side and a dull side, so I put the dull side to the block which is usually the way they go.
Anyone know about this gasket? It's symetric except for the spot the hole for dipstick is which might imply it could be flipped. I torqued them so I want to just cut away for the hole but if they only go one way then I'll have to get new ones. I've called Napa and no one knows.
Surfer69 is offline   Reply With Quote
Old 12-30-2006, 10:34 PM   #2
Surfer69
CF Senior Member
Surfer69's Avatar
Had to take heads off now for intake pushrod clearance problem with AFR 195 heads. Looked at gasket and I had place stamped numbers on gasket face down. Probably should have been face up but since all the coating material has come off I will get new ones and they're not that expensive.
Old 12-31-2006, 10:30 AM   #3
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Haven't used the Victor Reinz gasket you're asking about, but if it has rolled channels in the gasket face, the gasket is installed with the rolled channels facing down and their open side up as if to catch and channel fluids.
Anytime you have questions about a gasket, try the manufactuer's Hot Line/Tech Line. They should help you out with any questions about the installation of the gasket as well as recommended sealants. Hope this helps.
mr.beachcomber is offline   Reply With Quote
Reload this Page Can you flip this head gasket?
Tags
1191ve, 350, 5746, block, face, faces, flip, gasket, head, proper, reinz, side, up, victor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steering box rebuild-how hard?? Corbrastang C1 & C2 Corvettes 23 07-30-2005 06:40 PM
block decking fugawi C3 Tech/Performance 26 05-08-2005 04:50 AM
Oil Consumption cause by head rework? Ybnormal C3 Tech/Performance 20 09-21-2004 08:34 AM
Steering Box Rebuild Procedures GTR1999 C3 Tech/Performance 9 05-03-2004 09:42 AM
How to Set up & Install a 750 Speed Demon on a 350 (dial-up beware) lars C3 Tech/Performance 49 03-08-2004 08:49 AM
Water Temp going to 260! Oil guage shows cool Temp? Help 90whitevette C4 Tech/Performance 18 06-11-2003 12:01 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
