Here is a master list of engine weights...
http://www.35pickup.com/mulligan/weight.txt
Alot of the cars in the 60's only had 525 cold cranking amp batteries
from the factory... including Big Blocks... you can run a Honda battery
or a Group 26 battery and save weight over a group 24 or other heavy
battery... I did this while shaving my 1974 Dart's weight from 3100 to 2685 lbs.... I had full interior and A/C.. I saved almost 20 lbs with the
battery.
Aluminum heads
Al intake
Al waterpump
mini starter
Another cool thing you can do is use NASCAR hood hinges...
http://www.hutch-pagan.com/hood__mir...ies_pg_222.htm
it's kind of a pain to go stricty hood pins when no one is around to
help you lift it off..... all the Nextel guys use that type of hinge
and you can ditch the stock springs and hinges..... on old cars the
factory hinges can weigh a ton...
raceweight fiberglass hood, fenders,doors, decklids and bumpers
you can save quite a bit on wheels also.... I saved 80 lbs over stock
with all four wheels.
New Aluminum blocks are $4000.00... you can find used ones for
$2000.00 but many have been repaired... which is fine if the work was
good. I've seen quite a few aluminum blocks on RacingJunk.com
The fiberglass bumpers were a real help on the Dart... the stock ones
weighed 98 lbs ea.... the glass bumpers weighed 3 lbs ea...and were less than $100 bucks each..
You might check on tubular A-Arms for your suspension...
you could improve handling and reduce weight....
Lots of ways to skin the cat...
Good Luck!
