Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-17-2006, 09:58 PM   #1
big_G
CF Senior Member
big_G's Avatar
Default Rear main bearing question.
In process of upgrading rods/pistons on a 1,000 mile engine. The dark area in the pics. is smooth and the crank is a Scat 4340. Any comments?
__________________
Honey, I don't know how those black marks got on the driveway!
big_G is offline   Reply With Quote
Old 12-17-2006, 11:20 PM   #2
BLOCKMAN
CF Senior Member
Quote:
We have seen that color on the H-bearings and the F/M bearings right out of the box.
I see you have a stud kit installed on the mians but the caps have not been cut as far as I can see and when doing performace work it is recomended that the block be line hone when using there stud Kit.
And on 4 bolt blocks we don't use studs on the outside as over the last 33 years of bulding performance engines we have seen the outside studs cause cracks in the webbing of the main webbing mainly on the K-blocks do to the notch where the stud comes through webbing and we always have used a bolt on the ouside which does not cause the stress when the stud is bottomed out in the webbing of the block.
BLOCKMAN is offline   Reply With Quote
Reload this Page Rear main bearing question.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question....I dropped the pan and found..........? 1970-Bronze C3 Tech/Performance 19 05-24-2004 03:27 PM
rear main bearing, how to "inspect"? sb69coupe C3 Tech/Performance 14 04-30-2003 11:01 PM
What is a "Split" Rear Main Seal? Pic will Answer... paul 74 C3 Tech/Performance 11 06-27-2002 11:42 AM
Another "snake oil" question, or maybe not?? 65Z01 C4 Tech/Performance 9 04-06-2002 04:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
