Quote:
Originally Posted by patrik gustavsson
I need a new block for my -88 corvette. I would like to know which ones that will fit?? Do all blocks with a one piece rear seal up to -92 (LT1) fit ...how about the ones with 4 bolt mains (truckblocks).
If you are using a roller cam some of the truck blocks are not set up for roller cams as some of the truck engines were flat tappet cams and were not machined for the roller lifter as the lifter bores were counter bored and the holes were not drilled to hold the spider in place.
A new block the part number is 10105123
We have a 89 - 4 bolt in the shop if needed.
