Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Engine Mods
Outrageous Builds, High-Horsepower Modifications, strokers, and big cams for the Corvette Sponsored by
CARiD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-27-2005, 01:51 AM   #1
bigcityvette
CF Senior Member
bigcityvette's Avatar
Default dry sump pump
Do dry sump pump set ups save hp?
I really do not know squat about them except the oil is stored in a resivour vs the oil pan?
This prevents the crank from splashing into oil thus saving hp?
Can this be installed on a early 85 C4 Corvette?
bigcityvette is offline   Reply With Quote
Old 05-02-2005, 08:35 PM   #2
vette rod
CF Senior Member
vette rod's Avatar
Yes, a dry sump will give between 60 and 75 hp. Not only does this control the oil better but it will also scavenge air when it is not scavenging oil. This creates a vaccum in the crankcase (if engine is sealed, no breathers) that helps seal the rings better, pull oil of parts adding up to a less rotating mass as well as better oil control. It also depends on how many stage pump you choose to use. This could be installed on any car but it is critical to use the correct oil pan with a big kick out to take full advantage. I have one on my street car that makes 1080 hp with out nitrous. They are on the expensive side, around $2500.
www.pugesekmotorsports.com
vette rod is offline   Reply With Quote
Old 05-12-2005, 01:08 PM   #3
gofastvette
CF Senior Member
gofastvette's Avatar
Dry sumps dont add HP, it actually takes HP to drive them as they are really double pumps in the oil pan. They do have advantages, but also carry a lot of baggage. Such as a necessary large capacity remote oil tank and several lines running between the original pan and the remote tank. And the original pan never does get completely empty but that is a positive advantage making for smaller engine fires when a rod goes out the side at high RPMS`
gofastvette is offline   Reply With Quote
Old 05-12-2005, 01:29 PM   #4
redvetracr
CF Senior Member
redvetracr's Avatar
What a Dry sump gives you is "peace of mind" by having an adequate supply of oil....I don`t know about 60-75 hp but I am sure you get some due to the oil being scavenged out of the pan and NOT causing a paracitic drag on the crank, but unless your willing to "step up" to a custom set of headers a big kickout pan will not fit a Corvette frame...as to price, you can do it MUCH cheaper than $2500 although I have seen a $2500 oil pan so I guess it`s all in the components you pick, some pumps are scavenging so much oil out of the pan they actually have to reintroduce a spray of oil onto the piston pins for lubrication. I don`t really think it`s too practical for a street application as I remove the belt and prime the pump at the beginning of each weekend and heat the oil before EVERY startup. That being said I would NEVER race a car without a drysump system.
...redvetracr
__________________
redvetracr is offline   Reply With Quote
Old 05-13-2005, 07:44 AM   #5
chuntington101
CF Senior Member
for high hp aplications then i would recmend one or for modded cars doing road course. as for the power thing, well it takes less energy to drive a dry sump system than it does a conventional set up. so you are not making more power, just not using as much. there will be a weight gain. also a dry sump lets you mount the additional weight you have in a better place (ie in the back) to better weight distribusion. also as other have said it give you total piece of mind! even if the pumps cant get any oil, the system will still suply a constant presure, thanks to the tank. also the tank allows additional oil cooling (you could even have additional cooling in the tank).
and if it good enough for F1, WRC, BTCC, etc, etc, etc, its good enough for me! :-)
Chris.
chuntington101 is offline   Reply With Quote
Old 05-13-2005, 01:40 PM   #6
Ironcross
CF Senior Member
Ironcross's Avatar
I use them in my Nitro racing engines as a safety factor. Oil fires are the worst thing that can possibly happen
Ironcross is offline   Reply With Quote
Old 05-13-2005, 08:04 PM   #7
vette rod
CF Senior Member
vette rod's Avatar
There is tons of horsepower to be gained in a oil system if done correct.
Old 06-25-2005, 10:43 PM   #8
Baldturbofreak
CF Senior Member
Baldturbofreak's Avatar
Send a message via AIM to Baldturbofreak
I like them due to the fact that I can use a low mounted turbo without hassles with the drains.
Baldturbofreak is offline   Reply With Quote
Old 07-01-2005, 04:19 PM   #9
codyusa
CF Senior Member
CI 5-6-7-8-9-10 Veteran
codyusa's Avatar
Where do you find shops that will install these systems . Better yet, who sells the systems? I have a stroked out '87 and I googled a few places for information. I didn't get much help. Thanks.
codyusa is online now   Reply With Quote
Old 07-01-2005, 04:29 PM   #10
Ironcross
CF Senior Member
Ironcross's Avatar
Basically as race car application. Drag racing engines often are built with them too. Try the National Dragster news.
Old 08-21-2005, 01:51 AM   #11
Baldturbofreak
CF Senior Member
Quote:
Im about 6 hous away, I could set you up. I am in the process of finishing my own dry sump setup in my car (see avatar or www.baldturbfreak.com) Im sure your car will be no problem. It requires a custom drive mandrel to make it fit in behind the rack. I had to completely resdesign the accesory package to make it work,as my 5 stage would only fit up high on the driver's head. Your atmo engine allows us to run a 4 stage and still make good crankcase vacuum (so long as you buy a peterson or autoverdi pump) it can be run off your camshaft using a sprint car timing cover , utilizing a remote electric water pump. The oil tank is a stef's that fits in your rear compartment. It helps with weight distribution.
Reload this Page dry sump pump
Tags
corvette, drysump, pump, wwwpugesekmotorsportscom
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
