Pix of the new 406 on dyno...
Old 02-07-2005, 08:15 AM
chuntington101
chuntington101's Avatar
any more news on the engine? also could someone tell me if the how the whipple 2.3l compares in size (not displacment but space wise) to the Weiand 177? also what are the upper limits (in HP) of the Whipple?
thanks Chris.
Old 02-07-2005, 10:17 PM
JoeC427
JoeC427's Avatar
Originally Posted by Z-man
As a (possible) final footnote, by moving the spark map and changing the plug gap, we were able to find another 36hp and 20lb-ft or so today, putting the total at around 673hp. Max boost rose to 11.6lb.
Old 02-08-2005, 05:38 PM
bill mcdonald
bill mcdonald's Avatar
I am just kinda random posting here, I dont know if you covered it already...
I am wondering how you are firing the plugs? I see the crank trigger but I dont know how they work. It looks like your intake on the blower covers up where the distributer would be. So does this use a coil per cylinder or something?
I am very interested in this topic of crank triggers.
Old 02-08-2005, 10:19 PM
skid
skid's Avatar
Hmmmm, you started measuring at 3800 and the torque is dropping off from 713! What a beast! Better get some very sticky tires and a very strong tranny...
Old 02-09-2005, 07:51 AM
chuntington101
thanks JoeC427. i ment the limits of the 2.3whipple, sorry. also anyone have anything of the size of the 2.3 (compared to the weiand 177)?
thanks Chris.
Old 02-09-2005, 12:32 PM
mike 1985
mike 1985's Avatar
Default cooling
Nice HP and TQ #'s. Please get back to us on weather or not your able to keep the motor cool when it's in the car.
thanks
Mike
Old 02-11-2005, 12:58 PM
groovyjay
groovyjay's Avatar
This is one of the few very interesting on going projects on the forum. I like the stock look "stealth" appearance and almost 700hp/tq waiting to get unleashed! Keep us posted!
Old 02-11-2005, 03:45 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
Prices? I understand that the blower is about $3500 How much for the injection/computer........
My other question is? Can that manifold be tapped for injectors and run a sequential injection and FAST Computer with a O2 sensor in every primary tube?
I've kind of been looking into it because I have a motor that could be 8.3 compression with 76 cc heads and 20 cc dished pistons
Old 02-11-2005, 05:58 PM
7t2vette
The ORIGINAL and bestest
Support Corvetteforum!
7t2vette's Avatar
Toronto Events Coordinator
Have you made any more progress on your project? I am curious to see it installed in the car.
Old 03-09-2005, 01:28 AM
Z-man
Z-man's Avatar
Oh, well hey, I better wake up! I thought this thread sort of died so I haven't posted to it in a while.
Crank triggers still require a distributor but not points. There are several crank trigger distributors available, and I had to get a very low profile distributor to fit under the blower. You can see the black wires coming off it from the right in my second picture on the first page. The crank trigger takes the place of points and is much more precise.
For everyone else, I'm currently working on the fuel system and other boring engine compartment things before installing the engine. I'm adding a sump to the tank and running the lines, etc. It's taken longer than I had wanted since I lost my contract in January and had to spend time looking for new work. I'm settled in now and work will continue. I will post pics as work progresses. (Anyone ever run 3 inch exhaust under the car??)
Old 03-09-2005, 01:44 AM
Z-man
Z-man's Avatar
As I remember, the computer, harness and software was about $800, but I also sprung for a heated wide-band O2 system - $250 or so. The injection throttle body added another grand.
I discussed direct injection with Whipple and thought I would be tapping the manifold as you mentioned. Although you could probably do it, they talked me out of it. Their research points to better performance when the mixture is compressed (better mixing??). Also, the fuel pressure doesn't need to be so high. I'd be pushing the limits of the pump at about 70lb at my current rate.
To Pix of the new 406 on dyno...
Quick Reply: Pix of the new 406 on dyno...
