Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-20-2004, 11:20 AM   #1
ROJO99
CF Senior Member
ROJO99's Avatar
Default BFG Drag radials, what pressure are U running?
I am hesistant to go below 25psi. I have 275/35/18's on my basically stock 99 C5. I average mid 1.9's with the occasional feakish 1.85's for the 60' times.
ROJO99 is offline   Reply With Quote
Old 10-20-2004, 12:32 PM   #2
REDGAR
CF Senior Member
Cruise-In II Veteran
Cruise-In VI Veteran
CI VI Drag Champ!
Drag Race Event Coordinator
REDGAR's Avatar
You 60's are very good for a basically stock c5.
I run 19 in mine which are 275 17's
REDGAR is offline   Reply With Quote
Old 10-20-2004, 12:36 PM   #3
ROJO99
CF Senior Member
ROJO99's Avatar
My best 60' was a 1.808 which resulted in a 12.58 run. Sometimes a 3.5 clutch dump yeilds spinning thru 1st, and other times it bogs the motor. I am trying to do at least a 7 second burn-out. If I am feeling all macho and stuff I will hold 10 seconds or better and get the big plume going.
Old 10-20-2004, 01:45 PM   #4
robz
CF Senior Member
robz's Avatar
Quote:
I've gone down to 15psi with bfg's 315 35 17's with no problems.
robz is offline   Reply With Quote
Old 10-20-2004, 02:45 PM   #5
ROJO99
CF Senior Member
ROJO99's Avatar
At 15psi and the tire being a "radial" is this counter productive due to the tire contact patch is now concave in relation to the pavement?
Old 10-20-2004, 02:45 PM   #6
Greybeard ZR1
CF Senior Member
Greybeard ZR1's Avatar
The lowest I've gone is 20lbs. Which yielded a 1.74 60ft.(stock motor) Real low pressure can give you some real spooky handling, watch out.
__________________
91' ZR1 #1236, White/Black, Stock Engine, Jeal prom, Headers, Rippie Flywheel, 95MY trans., Hurst, 3"B&B's, X pipe, 4.10's, Forced Air intake, Drag Radials. 12.06@117mph. 1.74 60ft.
"Pushrods?.....We don't need no stinkin' pushrods!"
Greybeard ZR1 is offline   Reply With Quote
Old 10-20-2004, 02:59 PM   #7
Pete K
CF Senior Member
Pete K's Avatar
18 psi warm works for me.
Pete K is offline   Reply With Quote
Old 10-20-2004, 03:49 PM   #8
C5 CU
CF Senior Member
C5 CU's Avatar
16lbs, 295/18....4000rpm clutch dump with a little spin gets consistent 1.70.
__________________
C5CU -- (next C6-ZO6) SOLD-2002 EB ZO6, 456rwhp - 403rwtq, RPM 2 H/C, Vortex Ram Air w/power duct, S2 TB, Kooks 1 7/8 headers, x-pipe, stock Ti... B&M shifter, RAM 910 clutch/flywheel, hardened shaft, LS1-edit.---On drag radials 1.702 60ft...7.12 (101.40mph) 1/8th, 11.16 (126mph) 1/4.
C5 CU is offline   Reply With Quote
Old 10-20-2004, 04:00 PM   #9
robz
CF Senior Member
robz's Avatar
Not sure but I was able to cut 1.5x's on a well prepped track with 15 psi cold.
Old 10-20-2004, 04:06 PM   #10
ROJO99
CF Senior Member
ROJO99's Avatar
1.5 is just . I do not think I will ever get that close with 318 at the wheels.
Old 10-20-2004, 05:45 PM   #11
Matt383
CF Senior Member
Matt383's Avatar
Location: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
When I use DR's I go with 18 lbs all day.
Matt383
Matt383 is offline   Reply With Quote
Old 10-20-2004, 06:51 PM   #12
C5pilot
CF Senior Member
C5pilot's Avatar
I also use 19 psi in my 275 17's. Watch your 60' times along with tread wear when you think you're close.
C5pilot is offline   Reply With Quote
Old 10-20-2004, 11:06 PM   #13
MikeNMaxZO6
CF Senior Member
MikeNMaxZO6's Avatar
I run between 17.5 and 20. Seem to work for me.
MikeNMaxZO6 is offline   Reply With Quote
Old 10-20-2004, 11:50 PM   #14
Mr Mojo
Elite Torch Red Member
NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
You have to experiment, what works for us may not work for you. Too many factors involved.
But, I run 275/50R15's and have 22psi hot.
Mr Mojo is offline   Reply With Quote
Reload this Page BFG Drag radials, what pressure are U running?
Tags
bfg, drag, lowest, pressure, radials, raidials
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Launching a Z06 for drag racing oderja C5 Z06 Discussion 14 03-19-2003 11:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
