Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2004, 01:07 AM   #1
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
Default Whats it the lowest safe air pressure for et streets!
I have the ccw drag package with skinnies in front and tubeless et streets (26x11x16.5) for the dragstrip for my 98 C5 427 MTI car and i figure about 12lbs is the absolute lowest air pressure i can run with the et streets and still be 100% safe. What have the hardcore experts here experienced? What is the absolute lowest air pressure that you guys have run on tubelss et streets without jeopardizing any safety, etc? Keep in mind my car makes 480rwhp through its A4 4000 stalled tranny!
Thanks!!!
__________________
2006 Black C6 Z06, black powder coated rims, CAI; B&B Bullet Exhaust, and of course 427 Badges ; Mopar Jimmy is back with a daily driver 2008 Dodge Challenger, 450hp Hemi SRT8, runs 12.7s with bolt ons, & a mean, Ralleye Green, 1969 Plymouth Road Runner machine, 600hp 505 ci, black steel wheels & black fiberglass 6-pack lift off hood. Thanks and Praise to GOD!
Mopar Jimmy is offline   Reply With Quote
Old 10-16-2004, 08:57 AM   #2
vstella
CF Senior Member
vstella's Avatar
The last time I went below 11 lbs.psi I almost hit the wall when the car went sideways off the launch.. ..NOT FUN.
I think 12 lbs.cold is a good compromise for a safe run..the front at 38-40 IMO is adequate.
Don't forget that the closer the successive runs are together a higher psi will stay in the tire when the heat stays in the tire.Now you maybe at 13-14..always check the pressure before you run..
Good Luck and have fun..
__________________
E-Mail geminimuscle@yahoo.com
vstella is offline   Reply With Quote
Old 10-16-2004, 11:24 AM   #3
Z QQH 6
CF Senior Member
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Z QQH 6's Avatar
" always check tire pressure before you run"
Words of wisdom
__________________
2001 TR Z06 BPP VortexIntakeSystem Ripper Shifter WCC RearLens Bezels VaccessoriesGauge Bezels I/E decals S2Ported TB TPIS LT Headers Random Tech High flows & X pipe stock mufflers
Z QQH 6 is offline   Reply With Quote
Old 10-16-2004, 07:25 PM   #4
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
No other hardcore dragracers here have anymore info or input!!
Old 10-16-2004, 08:03 PM   #5
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Trial and error is really the only thing you can do. Each setup is going to want different pressure. I moved from M/T slicks that I ran at 13.5psi, and now the Hoosier's same size, I run at 17psi cold.
Rule if thumb is you want as much as possible, with no spin. The harder your tires are the quicker your 60' will be on equal bite. I might try 18psi cold tomorrow to see what it will yeild.
Same applies to suspension...hard as you can get it so long as you maintain traction.
In both the tires and suspension, any "extra" than needed movement is wasting energy that otherwise would be sending you in a forward motion.
The key however is finding the needed amount of movement
ski_dwn_it is offline   Reply With Quote
Old 10-17-2004, 11:04 AM   #6
JerryL
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
JerryL's Avatar
I make my first run with 12 PSI cold and bleed them down to 10.5 immediately after the run while they are still warm. I leave them alone after that. I've run as low as 10 PSI hot with no control problems. If the car trys to go sideways it's probably due to a burnout problem or parking the car where the sun heats up the tire on one side causing unequal pressures. My 60s run mid 1.4s on a well prepped track.
__________________
02 Z06
Cartek forged 427 (LS7): Callies crankshaft, Manley rods, Diamond pistons, ETP 240 heads, Jesel shaft rockers, NX direct port fogger, NX Maximizer, LSX Fast Intake, Kooks headers & X-pipe, Meziere water pump, Coan TH400 & converter with pro trans-brake installed by RPM, CCW drag package, Line-lock, Neverlift roll bar, American Super Car Challenge Serious Street Champion 2005 & 6
JerryL is offline   Reply With Quote
Old 10-17-2004, 01:11 PM   #7
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Sorry, can't help ya......haven't tried them yet, still using the BFGs
Allthrottleandsomebottle is offline   Reply With Quote
Reload this Page Whats it the lowest safe air pressure for et streets!
Tags
air, daily, driving, pressure, streets
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
