08-23-2004, 11:23 AM
CF Senior Member
C3 vs Z06
Street raced a Z06 on the weekend.
He took me off the line.
I had wheel spin and he did not.
Stayed with him after that.
Would have been better with my drag radials.
Could have would have
Should not steet race.
__________________
1976 Orange Flame/Black,4sp,PS,PB,Tilt/Tel,PW,383 stroker from GM/750 Holley with trick kit sitting on a Edlebrock dual plane intake,Stainless steel brakes, Fiberglass leaf, Bilsteen Shocks, BFG T/A 275/60 R15 rear/BFG T/A 255 60R15 Front,Glassed over headlights. Hurst Comp shifter,Crane Hi6 ignition.
08-23-2004, 02:18 PM
CF Senior Member
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
How far behind were you? If you run high 12's on DR's & were on street tires, that puts you into the 13's. A ZO6 w/ only a decent driver should go mid 12's on street tires. He should have beat you bad.
08-23-2004, 03:30 PM
CF Senior Member
He had me off the line by a car length. From then I could not run him down nor did he pull away. I run high 12's with street tires. fYI
08-23-2004, 11:04 PM
CF Senior Member
Quote:
Your sig says you run drag radials & run high 12's. Isn't that on DR's?
08-26-2004, 08:24 AM
CF Senior Member
No the times were with TA's not drag radials.
08-26-2004, 09:06 AM
CF Senior Member
Sleper...good stuff, hanging with a Z is strong...just be carefull which Z you pick-on, some are scary fast.
__________________
C5CU -- (next C6-ZO6) SOLD-2002 EB ZO6, 456rwhp - 403rwtq, RPM 2 H/C, Vortex Ram Air w/power duct, S2 TB, Kooks 1 7/8 headers, x-pipe, stock Ti... B&M shifter, RAM 910 clutch/flywheel, hardened shaft, LS1-edit.---On drag radials 1.702 60ft...7.12 (101.40mph) 1/8th, 11.16 (126mph) 1/4.
08-26-2004, 04:12 PM
CF Senior Member
Thanks for the heads up. I was surprized as well.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
