06-28-2004, 02:28 PM
CF Senior Member
1st time at track with new combo
12.76 @106.91 1.85 60' going through the traps at 4500 RPM
1985
355
9.3-1 comp
Dart Iron Eagles ( 180cc)
weiand stealth dual plane
224-234 @ .050 112 LSA 495-510 with 1.6
750 VS..elec choke
hooker supercomps
turbo 350
2500 stall
stock D36 with 3.07
26" tire
dual stage cheater kit.
here's a pic of the car leaving....i have a 4" cowl for it, i just need time to get it on.
img]http://www.photohost.org/gallery/data/500/4392e1483.jpg[/img]
06-28-2004, 02:45 PM
CF Senior Member
Re: 1st time at track with new combo (mike 1985)
nice!
06-28-2004, 05:29 PM
CF Senior Member
St. Jude Donor '05
Your picture!
[Modified by wallstAL, 1:30 PM 6/28/2004]
06-28-2004, 07:15 PM
CF Senior Member
Re: 1st time at track with new combo (wallstAL)
sounds like your having some fun
06-28-2004, 08:46 PM
CF Senior Member
Damn-impressive ET for a short-armed, tall-geared SBC.....
Were you on the bottle, or n/a?
If
on the bottle, what she run n/a?
07-07-2004, 03:11 PM
CF Senior Member
was that on motor or on spray
07-07-2004, 03:22 PM
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
07-07-2004, 03:32 PM
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VIII Veteran
St. Jude Donor '03-'06
07-08-2004, 12:20 AM
CF Senior Member
Re: 1st time at track with new combo (GrandSportC3)
07-09-2004, 01:08 PM
CF Senior Member
sorry all motor. 35 deg total timing.
I'm still working with the spray.
It leaves good, then starts to fall off and by high gear i have a surge, almost as if your turning the solenoids on and off.
It's a cheater kit with the stock jetting, the bottle was at 700 PSI and not exactly sure of fuel pressure. It's a carter 5-7 LB pump for the NOS mounted in front of the motor.
thanks for posting the pic.
07-09-2004, 04:38 PM
CF Senior Member
Good job!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
