Chevelle Drag Car
Re: Chevelle Drag Car (REDGAR)
thanks guys! Next winter the motor get done! Going to shoot for the 9.99-10.00 range!
-Rick
-Rick
Re: Chevelle Drag Car (vstella)
Any video?
I can email it to you if you want to see it. I am not sure how to post video on the forum!?!?!?!
-Rick
Re: Chevelle Drag Car (cicch95)
How much does it weigh?
Re: Chevelle Drag Car (ALLTHROTTLE&NOBOTTLE)
The motor is a 454 bored .030 over. It only has 10.5:1 compression with a fairly small HYDRAULIC cam for now. Holley 830 car, Edelbrock strip dominator single plane intake, Edelbrock Performer RPM aluminum rectangular heads (box stock), Hooker super comp headers.
The transmission is a turbo 400 with a B&M pro stick shifter. 4,500 stall convertor. Has a trans brake. Rear end is a Ford 9" with 4:29 gears, 35 spline Moser axles, and a heavy duty Moser Nodular case. Uses a 3 link ladder bar set up from Chris Alston Chassisworks. 8 pt cage with full hoop. Weld Aluma stars with 30X10 slicks.
I found it best to leave the line on the trans brake at 3,400 rpm. Car lifts the wheels about 4-6 inches! Added the bars from the cage to the front frame, so I am thinking it will go a little higher! Goes straight as an arrow. Runs pretty consistent at 10.87-10.90. 60' at 1.423 or so. Now if I could just cut a light!
Thanks for the comments guys!
-Rick
[Modified by cicch95, 10:22 AM 6/11/2004]
Sounds like a bullet proof set-up, I love a full bodied race car.
Now if my 331 cid would just die in my 68' Camaro.........
I built it too good ....in 1985
-Rick
