Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the & 1/8 mile, Events
CF Timeslip database
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-23-2004, 11:45 AM   #1
REDGAR
CF Senior Member
Cruise-In II & IV Veteran
CI VI Drag Champ!
REDGAR's Avatar
Default Pro racing question, why do the chutes come out early
I have been noticing what I thought was odd until I had it confirmed yesterday. It appears the drivers with chutes are letting them out before the finish line. In yesterday's drag racing on tv they showed a finish line snapshot as Jeggy just at the line and his opponent just before the line and both already had the chutes out though they had not oppened yet. They were just hanging right there.
REDGAR is offline   Reply With Quote
Old 05-23-2004, 12:21 PM   #2
INSANITY
CF Senior Member
INSANITY's Avatar
Send a message via AIM to INSANITY
Default Re: Pro racing question, why do the chutes come out early (REDGAR)
Whats up Bro. I asked merkel about that and he said the reason was so if the chute dont come out, they can try to stop with the brakes.. It gives them alittle more shut down..............
INSANITY is offline   Reply With Quote
Old 05-23-2004, 02:57 PM   #3
Fuzzy Dice
CF Senior Member
Cruise-In IV Veteran
Fuzzy Dice's Avatar
They've talked about that, very briefly, on TV before...they said the guys pull the chutes before the finish line because it takes a bit of time for them to open...they want them fully deployed at the stripe....
Fuzzy Dice is offline   Reply With Quote
Old 05-23-2004, 03:33 PM   #4
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
Default Re: Pro racing question, why do the chutes come out early (Fuzzy Dice)
mackeyred96 is offline   Reply With Quote
Old 05-23-2004, 08:20 PM   #5
MikeV
CF Senior Member
MikeV's Avatar
Default Re: Pro racing question, why do the chutes come out early (mackeyred96)
Talking to a pro I know and a few guys that do run over 180 MPH, they said that it depends on the following: 1: Track condition. 2: Type of race car. 3: Race situation. 4: Murphies law. 1: If the track has a shorter or bumpy shutdown area you have a tentancy to pull the shoot as soon as you can. The bigger the tire, the more the car wants to bounce. This is pronounced with a bumpy track. Every Pro pilot can tell you who has the worst shut down area. 2: If you have a car that is not sprung, I.E. a T.F. Dragster vs a Pro Stock car, it will bounce more in a bumpy shutdown area so you would pull the chute just before the finish line because it will not fully come out and fill until after the finish line. 3: In the pro ranks, if your loosing by a large margin at the 7/8 point in the track, you may as well pull the chute. 4: The worst one. The shute is folded up and installed with the large spring for what is called preload. This ejects the chute as soon as the cable pulls back far enough to let the spring release. Some of you OLD GUYS you may remember seeing a chute or two come out at half track or before. This happened because the chute release handle was set up to release with a rearward pull on the handle or toward the back of the car. With this configuation the handle could either rattle or move to the release position.
Mike V
[Modified by MikeV, 11:15 AM 5/24/2004]
MikeV is offline   Reply With Quote
Old 05-23-2004, 10:22 PM   #6
PRNDL
CF Senile Member
Support Corvetteforum!
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
Default Re: Pro racing question, why do the chutes come out early (MikeV)
I thought they were doing it to avoid breaking out!
PRNDL is offline   Reply With Quote
Old 05-24-2004, 05:40 PM   #7
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I was thinking the same exact thing this weekend. I thought maybe it came out automatically to a calibrated distance, say 10' short of the 1/4 mile.
Dr.Ron is offline   Reply With Quote
Old 05-24-2004, 07:11 PM   #8
Power Shifter
CF Senior Member
One of our local racers used to drive a jet dragster, She pulled the chute on a 300+mph run and it flaired the other jet seeing this aborted early(he was behind) to try to be there to help(in a crash) well jessaca got it slowed down enough to make the last turn before the sand/dirt pit, the gentalman that tryed to be johnie on the spot, rolled his jet on the turn. All good reason's to pull the chute on time, NO MATTER WHAT's going on. Ric
Power Shifter is offline   Reply With Quote
Old 05-25-2004, 06:57 AM   #9
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Default Re: Pro racing question, why do the chutes come out early (Power Shifter)
I rank in their with the hall of shame, how about the shut poping out on the burn out? The packer pulled the pin before the burn out instead of waiting until I staged and out it came .
:mad The crowd thought it was
FUNNY.
a shute doesnt last that long and if the track is rough they will pick up about 2 cups of rocks that tear the shute ,also the finish line is in the middle of the 3 lines the first and last lines are mph and when you are going over 250mph
you dont need a speed slip you only want the time!
good info on the above post.
[Modified by REDC4CORVETTE, 12:00 PM 5/25/2004]
REDC4CORVETTE is offline   Reply With Quote
Reload this Page Pro racing question, why do the chutes come out early
Tags
chutes, deploy, drag, finish, line, pictures, pro, prostock, pull, racing, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
