A simple Yes or No... re: 0-60 time
Who believes this.. a simple YES or No will suffice.. Although comments are welcome...
Someone said his street driven Vette (alleged 1/4 time 11.17 @ 122)
did the following......
QUOTE
________________________________________ __________________
my best 0-60 was 2.87 with vector's version of a g-tech. went to drags and was within hundred of a second!!! best 1/4 was 11.17 @122mph
[Modified by Red96Coupe, 9:17 AM 5/3/2004]
QUOTE
Re: A simple Yes or No... re: 0-60 time (Red96Coupe)
Doubt it. Maybe in an F1 car or something... (WITH launch control)
[Modified by eschoendorff, 6:10 PM 4/26/2004]
60' to 0-60 conversion
2.3 second 60' time = 35.5 mph @60' = 7.0 second 0-60 time
2.2 second 60' time = 37.1 mph @60' = 6.5 second 0-60 time
2.1 second 60' time = 38.9 mph @60' = 5.9 second 0-60 time
2.0 second 60' time = 40.9 mph @60' = 5.2 second 0-60 time
1.9 second 60' time = 43.0 mph @60' = 4.6 second 0-60 time
1.8 second 60' time = 45.5 mph @60' = 4.0 second 0-60 time
1.7 second 60' time = 48.1 mph @60' = 3.4 second 0-60 time
1.6 second 60' time = 51.1 mph @60' = 2.9 second 0-60 time
1.5 second 60' time = 54.5 mph @60' = 2.2 second 0-60 time
1.4 second 60' time = 58.4 mph @60' = 1.5 second 0-60 time
1.36 second 60' time = 60.0 mph @60' = 1.36 second 0-60 time
1.3 second 60' time = 62.9 mph @60' = 1.2 second 0-60 time
1.2 second 60' time = 68.1 mph @60' = 1.1 second 0-60 time
1.1 second 60' time = 74.3 mph @60' = 0.9 second 0-60 time
1.0 second 60' time = 81.8 mph @60' = 0.7 second 0-60 time
__________________
yes, it is possible if you can cut a 60ft in 1.6.
you only answer the question that you want to. my porsche goes to 0 to 60 in 3.7
if you do search in the tech section youll see a tread about gt40 going 0 to 60 in 3.2 and i beat you if it had nittos or bfg drags it'll go considerable faster
yes or no
i guess you think iam full of crap when i said my car trapped 122mph. its not that big of a deal! there are tons of c5 guys trappin that fast.
gm claims that they have seen sub 4 second 0 to 60 on the zo6, so you act as if i have a rocket on the back of my car. you dont even know me and your calling me a liar. i can't help it that you drive a sled!!!!!
__________________
yes or no
Elite Torch Red Member
I don't trust the G-Tech.
Re: A simple Yes or No... re: 0-60 time (Mr Mojo)
well its not a g-tech! and secondly i used it at the track and it was within hundreds of a second.
Yes, that et + mph = good 60. Probably in the 1.5-1.6 range. Although I dont put much stock in what G-Tech has to say...
[Modified by LSK, 5:01 PM 4/26/2004]
Johm, why should you care, let everyone have their own opinion even if they are wrong.
Re: A simple Yes or No... re: 0-60 time (mackeyred96)
Anyone have access to a radar gun? I drove a mustang (no flames please) that ran 10 flat with a 1.400 60' time.Felt like 2 sec. 0-60. Would be real curious to know some real times from real street cars. The radar gun and a stop watch would tell alot. Mid america had them for sale once. I wonder if anyone bought one?
Re: A simple Yes or No... re: 0-60 time (Pete K)
I did a little research: The Vector has a default rollout setting of 12 inches. I am pretty sure the Gtech has no rollout setting (in other words, zero). You all know what this means, right? The 0-60 timer does not start until the car travels 12". Obviously this will generate a lower 0-60 time than a zero rollout setting. Exactly how much lower, I dont know - figure it out! BTW, Chevy used a rollout adjustment to produce sub 4 sec 0 -60 times with the ZO6. MJ
Go down to page 15 ===>>>>>
http://www.beltronics.com/manuals/gx2manualrev1.pdf
[Modified by MNJack, 11:52 PM 4/26/2004]
Re: A simple Yes or No... re: 0-60 time (NICK YOSKIN)
Where did you get this table from? Based the table I have a 3.4 second 0-60 vette.
I have this crazy 5th order polynomial equation that estimates 0-60 MPH time based on 1/4 mile data. Using my Mustang as a test case, the formula predicts that car does 0-60 in 3.1 seconds (using test data of 11.30 @ 119 w/ a 1.606 short time).
So for a car that runs 11.17 @ 122 I find his claims believable that he could go 0 to 60 in 2.87 seconds. To run an 11.17 @ 122 the guy must of had a very good 60 foot resulting in a quick 0 to 60 time.
Re: A simple Yes or No... re: 0-60 time (Eric Fischer)
The 11.17 @ 122 mph would have been a 3.1x 0-60 mph with zero rollout.
But if you give yourself a 12" rollout, you would take off approxmiately .28 seconds off this, thus he would be around that 2.7 to 2.8.
I'm confident in my program that calculates these #'s.
I can give anybodys 0-60 mph times for them based upon their timeslips and a couple of other variables.
cheers,
Beach Bum
cheers,
Beach Bum
Jpee.... I couldn't give you a simple yes or no answer on anything, g, but what was stated is totally possible. Heck...even my Impala has done 3.97 0-60 with a 5th wheel attached
The only part that i cant figure out is what "drags" will give you 0-60 M.P.H. on a time slip...never saw that at a dragstrip before
Re: A simple Yes or No... re: 0-60 time (Hex29A)
Here is a 0 to 60 MPH calculator based on 1/8th mile times/ mph.
http://www.teamnabr.com/modules.php?...showpage&pid=8
I tried it with my 1/8 mile times/ mph (6.268 @ 114.35 mph) but it seemed very optimistic.
[Modified by TurboVette, 10:30 PM 4/27/2004]
Re: A simple Yes or No... re: 0-60 time (TurboVette)
That calculator is pretty cool. says 0to 60 in .68sec. Iknow I run zero to 100 in 2.1 and eighth in 4.6 at 155.Never knew zero to 60 but I knew it happened as fast as you are pushing on the throttle.I run a 1.06 sixty foot on a good pass.
Re: A simple Yes or No... re: 0-60 time (big632)
Re: A simple Yes or No... re: 0-60 time (eschoendorff)
Eschoendorff. Here ya go . http://www.temp.corvetteforum.net/c3/hotrod12
[Modified by big632, 10:15 AM 5/1/2004]
[Modified by big632, 10:16 AM 5/1/2004]
Hey Big ;
I got two words for you.. no make it 3.....
AWESOME.... F%^&*.... Car !!
I made it into wallpaper for my computer !! I'll give you my wife, a 96 Vette, & a 2000 Lexus for it... oh I'll even throw in the condo if you take the wife...
[Modified by Red96Coupe, 9:04 PM 5/1/2004]
