I Need To Know If It Matters Where You Install Your Line Lock....:confused: Does It Need To Be Cut In Before The ABS Block OR After? I'm Installing it on a 96 LT4. Any Help Would Be Cool. I Was Planning On Mounting it On The Driver's Side Front Wheel Well And Just Tapping Off The Front Brake Line..
Re: LINE LOCK Hooked Up With ABS? (mackeyred96)
Quote:
It must be piped into the front wheel line off the master cylender, before the ABS module.
I'll try to snap a pic of the install Mackey did on mine, as well as the install on my other car, it will give you two choices where to mount. As long as you can wait till Saturday.
