Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-27-2003, 08:21 PM   #1
vstella
CF Senior Member
vstella's Avatar
Default CCW Drag wheel setup..How do they fit?
Well I just purchased the CCW drag wheel/tire setup with the E.T./Skinny's and they look great! ..But..How did you have to modify the suspension to make them fit without rubbing inside the wheel. John at CCw asked me to flatten the rear A arm top cover with a hammer ..so I did..It's now FLAT! anything else I should know..???
What psi do you run on the road and at the track? John says 25 max on trhe road and 14 psi and lower at the track :rolleyes: How long a burnout? Anything else I should know..?
BTW.. here are some pics of CCW's shop in Daytona Beach..
Here are some extruded RAW blank center pieces BEFORE they go into the drill and cutting process..
Here is a sample of the same raw wheels being drilled and shaped BEFORE the Polishing and Buffing process.
Here we have John stocking a group of wheels drums in stock ready for the application of the center wheel component ..BTW..John lost some weight..Doesn't he look great!!
Some stock of finished wheels and see some of them are black anodixzed centers.
Now you can see some of the stock of tires John keeps on hand for matching with the wheels..MT E.T's..Firestone skinnies..Kuhmo MX..Hoosier slicks..BFG Drag Radials and more.
Here are MY new 16x9.5 and 16x5 wheels just before John mounted the E.T's and skinnies..The wheels are in the sun so that the silicone that seals the wheels joints cure.
[Modified by vstella, 7:22 PM 5/27/2003]
vstella is offline   Reply With Quote
Old 05-27-2003, 10:28 PM   #2
brent eb02
CF Senior Member
brent eb02's Avatar
Default Re: CCW Drag wheel setup..How do they fit? (vstella)
I HAD TO GRIND THE KNUCKLE DOWN ALITTLE....
brent eb02 is offline   Reply With Quote
Old 05-27-2003, 11:05 PM   #3
REDGAR
CF Senior Member
Cruise-In II Veteran
Cruise-In VI Veteran
CI VI Drag Champ!
Drag Race Event Coordinator
REDGAR's Avatar
Since you were nice enough post pics, here are pics of what you need to do to the rear. Bear in mind I did more than is needed. Do it in small intervals.
Some guys bang them down rather than grind
http://www.corvettechallenge.info/edgar/reargrind.html
REDGAR is offline   Reply With Quote
Old 05-27-2003, 11:06 PM   #4
Fuzzy Dice
CF Senior Member
Cruise-In IV Veteran
Fuzzy Dice's Avatar
Can't help you on the wheel question but thanks for the cool pics...I have to go wipe off the drool again... :D
Fuzzy Dice is offline   Reply With Quote
Old 05-28-2003, 12:10 AM   #5
QuickVet
CF Senior Member
QuickVet's Avatar
Default Re: CCW Drag wheel setup..How do they fit? (golfboy1)
wow those wheels look great. I never knew you guys had to go all that work to get them on. Congrats, I though you C5 guys didnt know what labor was, except how to pay for it :p: :p: :p: :p: :lolg: :lolg:
QuickVet is offline   Reply With Quote
Old 05-28-2003, 11:31 AM   #6
vstella
CF Senior Member
vstella's Avatar
Default Re: CCW Drag wheel setup..How do they fit? (REDGAR)
Quote:
..Some guys bang them down rather than grind
....REDGAR
WOW...What kind of tool did you use ? :rolleyes:
Old 05-28-2003, 11:41 AM   #7
Face
CF Senior Member
Face's Avatar
Send a message via AIM to Face
You went with the 9.5" rear wheels IIRC. If so, not much grinding/hammering is necissary. I'll email you a pic of how much I grinded off with a Rotozip.
Face is offline   Reply With Quote
Old 05-28-2003, 10:59 PM   #8
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
Vette Drs did it. I think they used a metal grinder.
Old 05-28-2003, 11:24 PM   #9
QuickVet
CF Senior Member
QuickVet's Avatar
:lol:
Old 05-29-2003, 06:44 PM   #10
urslooow
CF Senior Member
urslooow's Avatar
Vince what size wheels did you get and did you get them ground yet? When using this ccw setup are you more likely to break something with a high powered C5 A4 like ours? Does he make 17's and 16's for the rear and which are better?
urslooow is offline   Reply With Quote
Old 05-29-2003, 07:34 PM   #11
vstella
CF Senior Member
vstella's Avatar
Default Re: CCW Drag wheel setup..How do they fit? (urslooow)
Quote:
When using this ccw setup are you more likely to break something with a high powered C5 A4 like ours? Does he make 17's and 16's for the rear and which are better? ...urslooow
I have 16x9.5 rears and 16x5 fronts...I did grind the A arm knuckle but there is some slight rubbing ..I'll finish the job Saturday..hopefully NO MORE RAIN!
John makes all sizes but he recommend the 16's for the Drag setup..:yesnod:
Anything is possible when you launch with this kind of power but I've been careful and that's all you can be..:D :yesnod:
Reload this Page CCW Drag wheel setup..How do they fit?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
