05-26-2003, 12:37 AM
CF Senior Member
Nitrous? does 100HP really = 1 second?
Just wondering how much a shot of nitrous made in your 1/4 mile times.
I see in the NOS ads that 100 shot = 1 second in the quater.
Just wondering what it really did for your car.
How much are you running? what are your times with and without it?
05-26-2003, 07:31 AM
CF Senior Member
Re: Nitrous? does 100HP really = 1 second? (QuickVet)
I've been throwing around the NOS Idea for a while. But don't want to be throwing in another motor after it goes boom :D But if 100 = 1 Sec in good weather I could run a 10.80 Hmmmmmm :thumbs:
05-26-2003, 01:53 PM
CF Senior Member
Re: Nitrous? does 100HP really = 1 second? (RichS)
that is what im thinking :lol:
05-26-2003, 04:56 PM
CF Senior Member
Every car is different it depends on your combination. 1 sec out of a 100 shot is not realistic may be a 200 shot :D
05-26-2003, 05:27 PM
CF Senior Member
Sounds about right. The last time I sprayed at the track, I was running 13.6's pretty consistently N/A. When I sprayed, it dropped down to a 12.4 consistently. :)
05-26-2003, 05:43 PM
CF Senior Member
St. Jude Donor '07-'08-'09
12.7 on motor...11.8 with NOS...100 shot on a 02 6 spd
05-26-2003, 07:19 PM
CF Senior Member
Re: Nitrous? does 100HP really = 1 second? (vettejoel)
I like what im hearing fellas. I just have to hope i can make the kit work :smash:
05-28-2003, 05:21 PM
CF Senior Member
Depends greatly on current ET times and setup. The faster you currently are, the more juice you will have add to make 1 second difference. If you are running 13s now, a 100hp shot will pickup around 1 second. If you are running 10s now, you will needs around a 200hp to 250hp shot to drop 1 second.
05-28-2003, 11:26 PM
Guest
Re: Nitrous? does 100HP really = 1 second? (kromberg)
on my old mildly modded 87 100hp shot went from 12.9 to 12.1 and picked up almost 10mph......every car should have a 100 shot on it :D :cheers:
05-28-2003, 11:51 PM
CF Member
Re: Nitrous? does 100HP really = 1 second? (Kamarossrs)
If you liked 100 then you'd really like 150! It's a drug you know.
05-29-2003, 09:21 AM
CF Senior Member
Re: Nitrous? does 100HP really = 1 second? (97Brian)
:nono: not with my stock L48 bottom end :nono:
Tags
100 , 14 , 18 , 200 , 2001 , corvette , faster , hp , mile , nitrous , nos , pictures , shot , time , wet
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
