Weight difference BFG Drag Radials vs. M/T ET Streets...
Does anybody have the weight specs for both of those tires in similar sizes??
For example
BFG Drag Radials 275/60R15
and ET Streets 28 x 11.5-15
Does anybody know???
For example
Re: Weight difference BFG Drag Radials vs. M/T ET Streets... (GrandSportC3)
Olivier:
A more even comparison would be a 275/60/15 BF Goodrich Drag Radial vs. a 28x12.50x15 Mickey Thompson ET Street. Both of these tires have the same tread patch.
Are we thinking about running ET Streets now? :D
If so, trust me you'll love them....I have never spun coming out of the whole with mine.
*EDIT*
I have a spare bare rally rim laying around. What I can do is pull the rally rim that has the ET Streets mounted on it and weigh it. I can then weigh the bare rally rim and subtract the two. I run 28x11.5x15s. I really think that you'll find the weight difference to be very little.
[Modified by bence13_33, 4:51 PM 5/1/2003]
*EDIT*
Re: Weight difference BFG Drag Radials vs. M/T ET Streets... (bence13_33)
Olivier:
Olivier:
*EDIT*
*EDIT*
That's not because of better traction.. it's because of lower weight.. Wheels are centrifugal weight and worth 4 - 5 times the weight savings...
Re: Weight difference BFG Drag Radials vs. M/T ET Streets... (QuickVet)
Olivier:
:bs You are spinning. You just dont know it. Let me drive that thing. I will believe you when i see a vid of your crazy smoking burnout before you race :p:
Aaron:
I don't even need to heat the ET Streets up much now (usually about 5 seconds in the burnout box does the trick. I just let the clutch out, jump on the brakes and start heating them up. Coming out of the hole I am certain that wheel spin is VERY minute if any. 1st to 2nd never spins tire anymore, neither does 2nd to 3rd.
Even on the street these tire spin very little coming out of the hole with no burnout preperation.
Olivier:
You'll love the ET Streets. I can't imagine there being much of a weight difference....but traction will be a lot better. I thought you weren't going to run them for fear of busting the rear end? I'm hoping my rear end will make it through this season. Then I'm going to save and purchase a Tom's 12 bolt this winter.
Olivier:
11.5 x 16 x 26 ET street on weld prostar 16x8 - 35lbs
325x15x50 BFG DR on Weld 15x10 - 50+lbs
not the same exact sizes but best compare i have
Olivier:
Actually the 28x11.5 ET Street & 275-60 Drag Radial are VERY close in actual size...almost exactly the same when mounted. The 28x12.5 ET Street is close to a 325-50 Drag Radial. I have all 4 of these tires about 15' away from me right now :)
I dont have the exact weight if them all but the ET streets are about 1/2 the weight of D/R .... but don't get too concerned about actual tire weights with these. Even though the ET Streets are lighter you will run a little slower with them due to the type of sidewall construction... not much just a little but the car will be more consistant.
:party:
Cruise-In II & IV Veteran
CI VI Drag Champ!
Oliver I wouldn't think the tires weight difference would be substantial. Your weight reduction is in switching from that 1/2 ton 18" wheel to a 16"
Re: Weight difference BFG Drag Radials vs. M/T ET Streets... (ralph)
Re: Weight difference BFG Drag Radials vs. M/T ET Streets... (REDGAR)
