Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2002, 11:01 PM   #1
CORKVETTE1
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
CORKVETTE1's Avatar
Default longer wheel studs
when i went to the track today one of the officials came running over informing me and a lot of other guys well have to go to long wheel studs on the front and back they said something about some new rules :mad
CORKVETTE1 is offline   Reply With Quote
Old 11-03-2002, 11:23 PM   #2
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
Default Re: longer wheel studs (CORKVETTE1)
The rule unless they just changed it was that the stud must protrude into thr hex portion of the stud be the length of the dia.
mackeyred96 is offline   Reply With Quote
Old 11-03-2002, 11:27 PM   #3
scorp508
CF Senior Member
scorp508's Avatar
If your studs are for example 1/2" wide then they must go into the hexagonal portion of the lugnut that far (so 1/2" past the tapered part). Get the long ones so that they stick out past the nuts and they won't have issues with ya.
scorp508 is offline   Reply With Quote
Old 11-04-2002, 02:09 AM   #4
hookedup
CF Senior Member
hookedup's Avatar
Default Re: (scorp508)
Has anyone found studs that are long enough to do that with Weld's & 5/16 spacers? The Moroso's aren't long enough! :nonod:
Dave
hookedup is offline   Reply With Quote
Old 11-04-2002, 04:09 PM   #5
ROK 64
CF Member
ROK 64's Avatar
Default Re: (new92racer)
What's involved in changing the studs and where do I buy them. I'm getting ready to install Pro Stars on my '84.
ROK 64 is offline   Reply With Quote
Old 11-04-2002, 07:48 PM   #6
mackeyred96
CF Senior Member
john mackey
Dave
You are correct.
It's to close to call.
Old 11-05-2002, 02:03 AM   #7
pablocruise
CF Senior Member
pablocruise's Avatar
Dave
the ARP's aren't long enough either(shhh.........don't tell the tech inspectors around here) but they're working for me with the long shank nuts.
pablocruise is offline   Reply With Quote
Old 11-05-2002, 08:18 PM   #8
hookedup
CF Senior Member
hookedup's Avatar
Default Re: (89 Paul in Cal)
Hey Paul,
They're working for me to, but don't tell anybody, they're still not long enough! The only other thing to do would be try finding a stud with the same diameter knurl in SAE thread and use non-metric lug nuts.
Dave
Old 11-06-2002, 01:23 AM   #9
85vet
CF Senior Member
Cruise-In V Veteran
85vet's Avatar
Corkvette1,
Do you know when this new requiremnt kicks in. ie:minimum time like 12's.
Just curious - are you still redoing your motor? Just wondering time frame on heads.
Where were you this weekend? I thought the tracks were closed for the season.
Jim
85vet is offline   Reply With Quote
Old 11-06-2002, 01:45 AM   #10
scorp508
CF Senior Member
scorp508's Avatar
Guys,
There were differnt length lugnuts used over the years of C4s. I don't know what years had the shorter ones, but it might get you by.
Old 11-06-2002, 08:22 AM   #11
CORKVETTE1
CF Senior Member
Cruise-In V Veteran
CORKVETTE1's Avatar
Default Re: longer wheel studs (85vet)
the track guy told me they are going to enforce it starting next year. keystone and dragway 42 is still opened for a couple more weeks i am going back to keystone this sunday again as long as the weather holds out stil trying for that 10 sec et :cheers:
[Modified by CORKVETTE1, 8:03 PM 11/6/2002]
Old 11-06-2002, 07:35 PM   #12
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
The weather looks pretty good cork. I will be down to watch. I'd like to race but I would need a team of guys to push me around. :D
Talk to you on Friday! :cheers:
ski_dwn_it is offline   Reply With Quote
Old 11-06-2002, 10:04 PM   #13
CORKVETTE1
CF Senior Member
Cruise-In V Veteran
CORKVETTE1's Avatar
Default Re: longer wheel studs (ski_dwn_it)
bring the old mans car down :cheers:
Old 11-06-2002, 11:14 PM   #14
85vet
CF Senior Member
Cruise-In V Veteran
85vet's Avatar
Corkvette1,
How busy is it on Sunday?
I might come out for a couple hours. I was going to start tearing down the engine - But it can wait!!!
I see the gates open at 9 and racing at 11. What time do you normally get there?
Jim
Old 11-06-2002, 11:33 PM   #15
CORKVETTE1
CF Senior Member
Cruise-In V Veteran
CORKVETTE1's Avatar
85 i try and get there at 10 the last 2 weeks its been dead there but 3 weeks ago it was smashed so who knows :cheers:
Old 11-07-2002, 12:43 AM   #16
85vet
CF Senior Member
Cruise-In V Veteran
85vet's Avatar
I am definately planning to show :cheers:
Jim
Old 11-13-2002, 01:34 AM   #17
steve40th
CF Senior Member
St. Jude Donor '03 & '05
I use longer studs that work on my 93 with Weld Pro Stars. I use a factory GM part number, They are easy to install. I can get the number. they are about 3 1/2 inches long?? I got them from a friend here in Oahu, who I bought the wheels and tires from. I just raced this weekend and passed tech, well at least in hawaii, and they did look at the studs.
ps, I have H&R spacers for the rear. Trust me, these studs fit and they come to the end of the wheel lugs on the welds front and rear.
[Modified by steve40th, 7:36 PM 11/12/2002]
steve40th is offline   Reply With Quote
Old 11-19-2002, 03:19 PM   #18
Arnie
CF Senior Member
Cruise-In II Veteran
Arnie's Avatar
Default Re: longer wheel studs (steve40th)
Can you post the part # when you get a chance.
On doug Rippie's web site they show race lug studs that are 1" longer than stock, what are the stock lengths?
Thanks in advance...
Arnie is offline   Reply With Quote
Reload this Page longer wheel studs
Tags
1957, c5, c6, corvette, front, gorilla, longer, lug, moroso, murrosso, nuts, studs, wheel, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How hard is it to put longer wheel studs on the rear?? Gary2KC5 Autocrossing & Roadracing 9 11-19-2003 09:24 PM
Stronger, longer wheel studs? JUAN J SANCHEZ Autocrossing & Roadracing 13 08-02-2003 03:07 PM
GM PART LONGER WHEEL STUDS INFO GusBustamanteJr C4 Tech/Performance 9 04-30-2003 06:06 PM
Anyone installed longer wheel studs on a C5? TeamZ06 Autocrossing & Roadracing 12 07-15-2002 10:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
