Running C5Z fronts in rear for drag racing
I have seen people running the front C5 ZO6 wheels in the rears with drag radials before and I heard they work pretty well. If I were to want to run a second set of them on the rear of my C5 ZO6, what tire size should I run? Should I use a spacer? Can I run a bigger size sidewall because I will be running a 17" rim in the rear and not the 18" that came on the car?
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Sure can. No spacer needed. Lots run a 275/40/17 drag radial, but there are many sizes of 17" drag tires available. A lot depends on your power level.
Good luck and have fun!
BIGMAC
AMP Racing
Mac, several guys have run way into the 9s with that tire. I'd think it should work well for you.
would the MT 295/45/17 DR's fit on a 17X9.5 wheel? or would I need a wider wheel. I made 440 whp in mine. I can run a 275/40/17 if I have to but would the other tires fit?
AMP Racing
At your power level, I'd highly recommend the shorter tire. If you do switch to the 4.10, then I'd still say the shorter tire. RPM is your friend.
Taller tire isn't needed, or helpful, until you get to significantly higher hp numbers than what you're currently at.
AMP Racing
What size rim do you plan on using?
Do you need a DOT tire?
Hoosier and M/T has some good choices in the 27"-28" range too.
I was going to try the m/t on a 17 inch rim the 295/45r17. But I have read many people recommend staying with a shorter tire. I think that with the amount it spun at my last trip to the track, it would help and I like the look with more sidewall anyway.
AMP Racing
Shorter tires can be a very good thing. Especially if you have stock gearing or spin high rpm.
For most applications, however, with your gearing and power, I'd have to encourage a taller tire. 27-28"
Will after market 16 inch wheels fit on back of C5 ZO6 like CCW or Welds.
AMP Racing
For the most part, yes they will.
You will very likely have to tap the upper ball joint cap with a hammer, perhaps even grind a little off the edge of the upper part of the spindle.
This is pretty common. Lots of guys run a 16" wheel on the back of the C5.
AMP Racing
There is no perfect tire, as every combo is different..
The idea, in general, is to get as much sidewall as possible for our suspension limited IRS cars. This is especially true with a manual transmission.
Some have had limited success with an 18" drag radial. I'd guess they use it because a 17" wheel wouldn't fit over their brakes? That's the only reason I can think of.
If you're stuck using an 18" wheel, one more thing you'll need to monitor is the center of the tread not making contact with the track due to tire pressure being too low.
If you're just looking to go to the track and rip off some passes and have a good time, I'm sure the 18" will be fine. But, if you're like most, you'll quickly start looking for a bit better performance. The right tire can make a world of difference.
The bottom line is this; get out to the track and have fun. Be safe. Write down what works for you and what doesn't. Keep practicing. You can chip away at the ET with just little changes.
Good luck.
Good luck.
I think I made my mind up on tires, I didn't have much luck with the 275/40/17 I ran last summer. I want to run the 295/45/17 ET Street II's. Will those wheels fit on my c5z even though it is lowered on stock bolts?
