c3 drive shaft help
c3 drive shaft help
Hi, I am looking to install a stronger drive shaft in my 79, It will see some street and track. I will be putting down around 1000 hp in the future and want to do it once, what are my options for a stronger drive shaft and a loop in the stock tunnel?
Thanks for replies.
Thanks for replies.
1 Post
Thanks for replies.
Thanks for replies.
Thanks for the reply & pics. I was considering attempting a 2.75" thick wall driveshaft but don't know how well a driveshaft loop will fit.
I like your crossmember mod for the exhaust. What mufflers are those you are running?
Your exhaust is tucked up there nicely.
I stuffed a 3" chromoly one in my 78 and its tight. I am going to have to beat on the tunnel a bit to get a loop in there but it'll work.
cant beleive you are running the stock unit Vettekid. Wish I knew it would hold up like yours is before I put the 3" in.
