Stock LS2 W/ Cam and A&A kit almost hit 9's
We have been playing around with this car for a little while just picking away at it. Going faster and faster each time. Last year we went 10.20 on the stock wheels with drag radials. We switched up the wheel/tire package to help us reach our goal of 9's with the stock motor.
Only mods are Cam with associated parts, 1 3/4kooks headers, Corsa Catback, V3SI A&A kit, Meth Kit, Mcleod RXT clutch, and 06+ rear diff since this car is a 2005.
That 60 is great! But if you can get it done with that MPH that's a 9.50 car!
Time for a glide!
Time for a glide!
With that trap speed you should should be able to hit a high 9 contingent on the track conditions. I would try some different tire combinations such a switch to bias ply tires in the rear and see if you can improve that 60' time. There are a lot of stick shift guys who swear by the drag radials, and some who swear by bias ply tires. I say find what works for you and your driving style, although for a stick shift car a bias ply tire in the rear might be easier on the drive train components. Good luck for your quest for 9's.
The short block and the heads are stock.... Hence why we say cam and blower.... Its stock besides that.
