Looking for sponsors
Cruising
I am planning on building a mile event car. I am planning on using the new stingray corvette. It will have a Nelson Racing Engine in it.
932ci
5.300" Bore
twin 122mm turbos
125 Shot of nos (to assist in spooling of turbos)
Lenco cs1 5 speed with reverse gear lever shifted trans ($10, 050)
Suspension upgrades and roll cage will need to be done. Any help on finding a sponsor? How do I approach potential sponsors? Any advice. What companies would be a good starting point? I will be willing to drive to any event possible no matter how far away.
932ci
5.300" Bore
twin 122mm turbos
Hell just send me a PM & I'm good for $50K that should be enough to get you on your way...
Good luck with the project... BTW Where are you .... you never filled out your profile...
If you want I can run out Mon. morning and pick up the turbos...at least its a start...
My Camaro made 721 HP from a 290 ci small block Chevy engine at 9600 rpm the car ran 8.03 @ 171 mph back in the 1990's Now D/A cars are running well into the 7 sec zone ....
Also Pro Stock (yes a little less power) and Comp Eliminator car (I had a D/A Camaro) and we and the Pro Stock cars use LIBERTY TRANSMISSIONS !
Cruising
Wrong !!!... what do you think Pro Mods use or Alcohol Dragsters & Alcohol Funny Cars.... it called a LENCO TRANSMISSION
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
What happened with the drag racing team sponsorship and the 4000HP motor?
http://forums.corvetteforum.com/drag...cing-team.html
Cruising
Cruising
