3.15 to 3.73 gains?
My heads/cam C5 went 11.40's with a 2.56 gear on the NA tune (430 rwhp). I swapped the gear for a 3.42 and then had the motor retuned (pulled 8* of peak timing for the spray). On motor is still ran 11.40's after the rear swap and timing pulled (411 rwhp). My problem now is, traction has become a major issue.
Frank
How much cam and head work? I stayed kinda smallish on the cam. It's a COMP XER281. 232-234 @ .050" / .595"-.598" with a 112 LSA. Heads flow 305/220 @ .600". Bottom end is a stock crank, Probe forged 11:1s, Eagle 6.125" rods, King bearings, Mahle moly rings. Cometic .051" gaskets, COMP double roller, SLP oil pump, Scorpion 1.7s, 42# Racetronix, LS6 intake, 4L60E, and 3200 stall. Hell, I'd like to see and 11.7 on motor.
Frank
Frank
Frank
Frank
Very cool, I'd figured you had to know him. We used to hang out at the tracks all of the time back in 2001-2004, he was like the lone LT1 guy among a sea of LS1 people, he was always a good guy.
That is very impressive to say the least.
Frank
Frank
Received 3,043 Likes
St. Jude Donor '05
