Check our version of the Big 3!
Supporting Vendor
Hi Everyone!
We have put together a Big 3 kit for you that is easy to install!
With all of the high-tech electronics that have been incorporated into your C5 Corvette, not to mention additional after market electronics and stereo systems, it can take a toll on the factory charging systems ability to keep up. Especially if, over time, connections have become corroded.
Installing a BIG 3 upgrade can be very beneficial as many on the Corvette forum will tell you. SacCityCorvette has developed a BIG 3 installation kit for the C5 Corvette. It is made from all high quality materials and designed so it will not look like an aftermarket universal kit. For safety it has a 100 amp heavy duty fuse, uses automotive grade 4 gauge wire, (not the type most car stereo shops use), the positive wire has a mesh sleeve over it for additional protection, all connections are hydraulically crimped and come with all the hardware needed to do the install. The installation takes about thirty minutes with simple hand tools. If you have doubt that this BIG 3 kit will make any difference in your charging system, please check out our test video below and see how the voltage increases when we connect it! Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
Here is the link with all the info. http://www.saccitycorvette.com/Big-3.html
Side terminal $119.95 Top Post $139.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Top battery terminal mount Big 3 now avaiable!
Check it out! http://www.saccitycorvette.com/Big-3.html
Supporting Vendor
Supporting Vendor
Our Vette just seemed like it ran better with the Big 3 installed.
Could be in our heads or could be the that the extra voltage
really helped. Just saying!
Supporting Vendor
This is a great add on for you that have after market stereo systems
Supporting Vendor
Hi TLTONEY,
As a matter of fact we do. Since we have received such a great response for the C5 Big 3 we have been prototyping a Big 3 for the C6.
The photos above showing the top post setup is on a C6. As you can see its a very clean no modification to your C6 install.
We should have it on our website in a couple weeks.
Christian
Christian
Supporting Vendor
We offer more products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will get back to you with quotes and do our best to save you some money
Thanks,
Matthew
Thanks,
Matthew
I watched your install video and it looks simple but I do have one question. Does this completely replace the OEM cables or does it work in conjunction with the OEM cables.
Thanks.
Thanks.
Supporting Vendor
Our Big 3 works in conjunction with the factory charging system wiring that has shown to be on the weak side. So there is no modification to the factory wiring.
Christian
Supporting Vendor
Supporting Vendor
