Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
How to cut a .500 light
Old 05-30-2002, 01:18 PM
88-406's Avatar
St. Jude Donor '05
Default How to cut a .500 light
Does anyone have any technique they'd like to share? Wich yellow are you guys reacting to? How do you stage? does that have anything to do with it?
KM
Old 05-30-2002, 02:16 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: How to cut a .500 light (88-406)
Per stage, Stage.
Close your eyes, count to 3, and launch.
Thats as good as any method.
You can't copy anyone here, just to many thing that control launch/ reaction time. You must fine what works best for you.
I know there are racers her like Beach, OD, Ralph, Panuzzo and myself that could talk for days on this topic and thats because we tried it all.
[Modified by mackeyred96, 1:17 PM 5/30/2002]
Old 05-30-2002, 05:33 PM
REDGAR
REDGAR's Avatar
Cruise-In II & IV Veteran
CI VI Drag Champ!
Practice. However, trying to cut .500 is very dangerous. If you miss too early you will go red. i try to hit a .5teen light each time.
You have to experiment. Car, track and driver will make launches very different.
I have an A4. I load my converter to about 2000 and watch for 3rd yellow to come on. This is with a very shallow stage. If I do not load, I cut bad lights.
I have cut a few .50x lights recently but usually am a high teen to high 30 range
Old 05-30-2002, 05:46 PM
Face
Face's Avatar
Default Re: How to cut a .500 light (REDGAR)
I normally launch from idle and stage shallow. On the 3rd yellow I smash the gas to the floor and usually wind up with a .52-.55.
Old 05-30-2002, 07:25 PM
jpee
jpee's Avatar
Default Re: How to cut a .500 light (Face)
It really depends on how your are seeing the lights on the tree, & how fast your car reacts to you mashing the gas..
Example if its a "BRIGHT SUNNY" day & I hit the gas as soon as the last yellow goes on I am around .540 - 560 however if its "NIGHT" racing & I hit the gas as soon as I see the last yellow I'll go RED..
The reason in the dark you see the filament of the bulb light much sooner than in the bright light...
Another thing is staging, if you light the bottom bulb, & accidently go in another 3-4" you reaction time will be quicker.. maybe TOO quick... :(
It's a science, & PRACTICE
Old 05-30-2002, 10:13 PM
88-406's Avatar
St. Jude Donor '05
Hey, does everyone have an automatic or what ? Anyone with a manual care to comment on technique? I imagine there must be a difference.
KM
Old 05-30-2002, 10:16 PM
CFI-EFI
CFI-EFI's Avatar
Default Re: How to cut a .500 light (Red96Coupe)
Science, my...!!! It's strickly voodoo!
Otherwise, you get .500 lights the same way you get to Carnegie Hall.
Good luck.
Old 05-30-2002, 10:30 PM
mackeyred96
Then I raced my 4 SPD super stock chevelle. On the first yellow I bring the revs up to 9000 and on the last yellow side step the chutch and hold on.
Try that with your Vette, It would be a fun ride aleast once. ;)
Old 05-30-2002, 10:36 PM
Beach Bum
Beach Bum's Avatar
Default Re: How to cut a .500 light (mackeyred96)
footbraking with no electronics its luck to hit a .500 regardless of who you are.... but its a lot of practice and some skill to consistently be right off that #.
When you figure it out... let me know, I could use the help. :)
cheers,
Beach Bum
Old 05-30-2002, 11:03 PM
geekracer
geekracer's Avatar
Check out http://www.staginglight.com/guide/react.html This is a pretty good explanation of what is going on. :yesnod:
To How to cut a .500 light
Quick Reply: How to cut a .500 light
