Aeromotive Drop-in A1000 Corvette Stealth Fuel Pump Kit for the 2003 1/2 - 12
Former Vendor
St. Jude Donor '13
Finally, a solution to your Corvette’s fuel system needs. No more drilling your fuel tanks, no more risking pump failure in a 1, 2, or 3 pump set ups, no more surge tanks, no more mess. Aeromotive has engineered a patent-pending, complete drop-in fuel system available for C6 and late C5 Corvettes. The system provides a single A1000 Fuel Pump capable of supporting big HP. The best part, it’s a complete drop-in assembly into your factory tank that still incorporates the factory jet siphon system. Now you can plumb a true return-style system into your Corvette without the worry of the siphon system and while using the factory fuel tank.
• Fits 2003 1/2 and later Corvettes (Late C5 and C6)
• Supports up to 1300 HP – naturally aspirated
• Supports up to 1000 HP – forced air induction
• ORB-10 outlet port
• ORB-06 return port
• Incorporates factory jet siphon system and sending unit
• Includes an integrated 100-Micron Stainless Steel pre-pump filter
• Utilizes the factory tank, o-ring, lock ring and mounting location
• Includes all necessary fittings and hardware to plumb the pump into your tank.
$739.95
in stock
free shipping lower US
in stock
Install instructions
http://aeromotiveinc.com/wp-content/...8670_18671.pdf
Former Vendor
St. Jude Donor '13
http://www.xplosiveperformance.com/D...te_p_3081.html
$739.95
in stock
$739.95
in stock
Former Vendor
St. Jude Donor '13
$739.95
in stock
$739.95
in stock
