Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Want to buy my motor?
Old 04-11-2012, 08:58 PM
L79racer
L79racer's Avatar
Default Want to buy my motor?
Thinking about selling my motor. I want to build an LS motor but no need to if I have this one. If interested lets talk. Looking to get about $5000 for it. If you were to build this it would be over $8600 in parts and machine work alone. 383 sbc about 560hp on pump gas 11.0:1 compression.
Gm 010 high nickel block
Machine work Bored/align honed torque plates clearance for stroke etc
eagle rotating assembly 4340 H beam rods arp bolts
Ati super damper
Comp cam solid roller
Crower hippo lifters
TFS chromemoly .080 wall pushrods
AFR comp ported 195 CNC heads
Comp cam pac roller springs
Comp cam Titanium retainers
Harland sharp Roller rockers 1.6
AFR stud girdle
Aluminum valve covers
Aluminum water pump
Edelbrock vic jr cnc
Msd pro billet distributor
Milodon pro comp pan/windage tray
Melling hvhp oil pump
True roller timing chain
Old 04-15-2012, 08:23 PM
flynnd_33
flynnd_33's Avatar
i was always curious and im sure others always have been whats the cam specs for that motor?
Old 04-15-2012, 09:23 PM
L79racer
L79racer's Avatar
Its a small street roller. 255/262 duration@.50 574 lift, I use 1.6 rocker for a gross lift of 613. It does not have a very aggressive lobe like a true race roller cam so it doesnt kill springs.
Old 05-13-2012, 04:35 PM
Ryan59
Ryan59's Avatar
Isn't the 030 block the high nickle block?
Old 05-13-2012, 05:22 PM
LS1LT1
LS1LT1's Avatar
Ati super damper
AFR stud girdle
Aluminum water pump
Has this motor been proven at all, like, have you gone a couple rounds or won any races at the track with it or anything?
Old 05-13-2012, 08:26 PM
Vettekid1992
Vettekid1992's Avatar
Old 05-13-2012, 09:24 PM
L79racer
L79racer's Avatar
Little info. Mine is a 3970010 with the 010/020 Got the below info off the net.
A block's alloy content is denoted by two figures cast into the front face, just above the main bearing bore, in the area normally concealed by the timing cover. Many production small blocks have the numbers "010," "020" or both cast into their front face, just above the main bearing bore. If both numbers are present, one above the other, it indicates that the block alloy contains 10% tin and 20% nickel. A single number, either a "010" or "020" represents the amount of nickel and indicates negligible amounts of tin.
No numbers, other than the casting numbers that are typically found beneath the timing cover, translates to only minor amounts of tin and nickel being present in the block alloy. (Tin and nickel are two metals that are commonly alloyed with cast iron to improve durability, hardness and heat dissipation.)
Although a "010"/"020" block is most desirable, it's not always possible to find one that's suitable for high performance use. Alloy composition aside, cylinder wall thickness is the overriding consideration in block selection, and one with no tin or nickel and thick cylinder walls is generally preferable to a high-nickel block with thin walls.
Old 05-13-2012, 09:26 PM
L79racer
L79racer's Avatar
maybe a few.
Old 05-13-2012, 09:39 PM
LS1LT1
LS1LT1's Avatar
maybe a few.
Oh no doubt LOL...but just in case, here's a list of "witnesses" who can vouch for seeing that motor in action first hand:
2. Anthony S. Cupolo
3. Eric Fischer
4. Shawn Cavanagh
5. Paul Bogdan
6. Marshall Brown
7. Tommy Michalkowski
8. Rob Petyo
9. Adam Brandt
10. David Shen
To Want to buy my motor?
Quick Reply: Want to buy my motor?
