Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2009, 01:09 PM   #1
HP_Addict
CF Senior Member
HP_Addict's Avatar
Default C5 Suspension:QA1s or Coil-overs
So I was at the tack on Sat and I think I have reached the point where I have more power than my stock suspension can handle. I am looking at adding QA1 shocks all around or coil-overs. Which is preferred with the racing crowd? If coil-overs which brand?
HP_Addict is offline   Reply With Quote
Old 11-18-2009, 02:39 PM   #2
K RIPPER
CF Senior Member
Have 03 z/06 battling wheel hop last couple years pfadt trans brace,QA1 All around poly bush in rear all have helped none cured.Made it a point to seek out the brightest corvette drag/road race guys,chassis guys and professional race car builders all have recommended coil overs esp. if you go for more HP.Knowing what I know now if I had to do it over I would put in coil overs,all name brand coil overs are good but QA1 are helpful,good to do business with and they make a very nice piece
K RIPPER is offline   Reply With Quote
Old 11-18-2009, 05:48 PM   #3
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
I have had both Qa1's shocks and now Pfadt coil overs, and there is no comparison, the coil overs are so much better. The street ride is much better, and my car cutting 1.28 60' times IRS sums it up pretty well.
I believe we have them in stock ready to ship if your interested.
DOUG @ ECS is offline   Reply With Quote
Old 11-18-2009, 07:53 PM   #4
HRTBRCR
CF Senior Member
HRTBRCR's Avatar
Default coil overs
just had mine installed, the phadt units...I recently had the phadt inverted shocks on the car...the coil overs are just truly awesome...there really "IS NO COMPARISON", none...
vinny
HRTBRCR is offline   Reply With Quote
Old 11-18-2009, 08:11 PM   #5
K RIPPER
CF Senior Member
Do they come with bracketry,are they bolt in? Do I assume correctly the shocks are double adjustable? Where do they mount? on a scale 1-10 how difficult and how big of a PITA is it to install how much grunt work?I'm a retired mechanic got the know how and the tools but lack the strength and stamina.I'll give you a call f/price and avail.thanks
Old 11-18-2009, 09:23 PM   #6
4DRUSH
CF Senior Member
4DRUSH's Avatar
Quote:
Their direct bolt in, no basketry needed. They are 16 position single adjustable. The springs come pre adjusted for the ride height, but have wrenches included for additional adjustment.
You'll need to have the car on jack stands. The mono spring (under the carriage) gets deleted. You need to unhook the upper A arms from the frame to slide the shocks in. Then jack the lower A arm up to compress the shock to reattach the upper A arms (not hard at all) You also need to unbolt the coolant expansion tank & WW fluid tank to access the top of the front shocks.
They also require you to drill a small hole in the trunk/storage compartment straight up from the top of the rear shocks, so you can get to the adjustment on the very top of the shock. I cut a little x slice in the carpet. (that you can't see)
4DRUSH is offline   Reply With Quote
Old 11-18-2009, 10:34 PM   #7
HP_Addict
CF Senior Member
HP_Addict's Avatar
Guys thanks for the info. I will definitely consider the PFadts.
Will the QA1s work on a lowered car? My car is lowered about 1.5" My stock shocks would bottom out, but the Bilstein sports are a bit shorter and work better.
Old 11-19-2009, 05:28 AM   #8
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
TUNING TIPS
Shocks are just one of many suspension variables on a race car. However, a current trend is to focus on the importance of the effects of shocks on the performance of a race car. With this in mind, we have included a few tuning tips and observations about our series shocks.
Virtually every car will separate at the launch. The rear suspension system forces the chassis upward while pushing the axle housing down. This is typically the first movement for most drag cars. For this reason, the extension, or rebound control, of the shock is extremely critical. The chassis tuner will need to have a shock that has a broad range of adjustments--a shock that will make a noticeable change in suspension characteristics when the shocks are adjusted.
The key elements to tuning the chassis are how quickly and with how much force the axle housing separates and drives the tires into the starting line. Starting lines that are bald, slick, or extremely hot will usually lack good traction. Therefore, a shock that has had the extension (rebound) softened will create more traction (greater separation). As the tire wraps up, the axle is driven down, and the chassis pitch rotates, the sidewall of the tire is compressed. At some point, the torque from the engine will decrease or the chassis will reach maximum pitch rotation. When this occurs, the tires will start to return to their original form perfectly round. This action can cause wheel hop or can "unhook" the tire. Here is where the compression setting becomes critical. The compression valving can now be set stiffer to hold the tire down on the track. This method of shock tuning is used by many of the most successful drag racers in the sport today.
CONSISTENCY
Currently the largest number of competitors in drag racing competes in some form of E.T. (bracket) racing. The premise of bracket racing is to predict the E.T. of the car as accurately as possible. The race car must be setup with quality components that promote consistent E.T.'s run after run. Common areas for tuning have included tire pressures, new tires, and launch RPM. The link between the chassis and the track is the shock/spring combination. A high quality suspension system will load the tires evenly from run to run, thereby promoting more consistent E.T.'s and allowing E.T. prediction to be more accurate. More accurate E.T. prediction equals more round wins equals more success and money.
AN INVESTMENT IN PERFORMANCE
The world of technology is ever changing, and in drag racing this is also true. A quick check of the competition will reveal that many have improved their programs, race cars, or teams. The goal is to better last year's performance or records. With that in mind, a constant evaluation of the combination is a must. From Pro Car to Competition, from Super Stock to Super Gas to Super Comp, from Super Street to a bracket car, a high quality set of shocks can and will improve the success ratio and will return its investment many times over. Drag shocks will last for several seasons. If the cost/value relationship is evaluated over time, the initial investment price can be justified by the opportunity for improvement that the shock provides. AFCO shocks will make a positive impact on your racing success!
__________________
Johnny Carson once said.A married man may live longer ,but is more willing to die.
REDC4CORVETTE is offline   Reply With Quote
Old 11-19-2009, 08:31 AM   #9
Higgs Boson
CF Senior Member
those of you with pfadt coilovers, are you using the regular kit or the drag setup they now offer? what shock settings are you using? thanks!!!
Higgs Boson is offline   Reply With Quote
Old 11-19-2009, 06:33 PM   #10
4DRUSH
CF Senior Member
4DRUSH's Avatar
Quote:
The drag setup is softer springs in the regular front coil overs. If you have them you can convert easy.
I started in the middle setting and only made one change so far.
(fronts are on 7 now)
Old 11-19-2009, 07:40 PM   #11
C6-13thPilotCar
CF Senior Member
C6-13thPilotCar's Avatar
I just had Pfadt coil overs and sway bars installed on my 05. I race it a dozen times a year on the drag strip. The ride and handling on the street is unbelievable. It rides like a new car. The shocks are adjustable with 16 settings. On the strip I changed the settings and got my best 60 foot times with no wheel hop. went from 11.70 to 11.50 just with suspension and seat time. I don't know anyone who installed Pfadt didn't like them.
C6-13thPilotCar is offline   Reply With Quote
Old 11-20-2009, 09:17 AM   #12
Chris@East Coast Supercharging
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Chris@East Coast Supercharging's Avatar
Send a message via AIM to Chris@East Coast Supercharging
Quote:
How is the clutch doing?
Chris@East Coast Supercharging is offline   Reply With Quote
Old 11-20-2009, 12:39 PM   #13
K RIPPER
CF Senior Member
Quote:
Guess you imply the bite and 60' times should some remarkable impovement,good ,,just a couple more questions must front and rears be done at same time?(x mas next month taxes ,Jan. 1st.,Ins. due Jan.)you get the picture.And last I know there are no guarantees in life but will I connquer wheel hop once and for all as that is of the umost importance to me as that can put a hurtin' on my vette and I just finished major ddriveline repair/upgrade.I used a complete C6 Z/06 clutch setup had a sprung hub metallic disc and hated it your opinion on the C6 clutch am I safe foor now...thanks for taking tne time and answering these rookie questions
Old 11-22-2009, 10:17 AM   #14
C6-13thPilotCar
CF Senior Member
Big difference, turned by best times with it so far.
__________________
Pilot Car-13th C6 built, Precision Red
Build date 4/2004
ESC Novi SC, Meth, Ron Davis Radiator & Engine oil cooler, Ported T/B, Upgraded injectors, ESC Blower cam, SLP oil pump, CNC Trick Flow 225 heads, LG Pro headers and x-pipe, GCA exhaust, C5 Z06 - DTE Stage 5 Diff. with brace, Stage 2 MN6 trans, Twin disc clutch, Pfadt Coilovers & Swaybars, MGW shifter. Hooiser drag radials,
ESC Dyno Tuned. 665 RWHP, 625 RWTQ.
Reload this Page C5 Suspension:QA1s or Coil-overs
Tags
c5, coilovers, corvette, drag, qa1, suspension, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
