Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2009, 12:45 PM   #1
bluzman2004
CF Senior Member
bluzman2004's Avatar
Default C3 Roll Cage help?
Can someone with a C3 and 10 point roll cage help me out? On the 2 bars that are in front of the driver, that go from halo bar above the driver to the floor by the drivers foot, how is yours attached to the floor/frame? Is it somehow welded directly to the frame rail there (doesn't seem possible by itself), or did you use a 6" plate welded to the floor, or can you weld a bracket off the frame and weld the bar to it?
Just wanted to see what has been done and what's legal for tech.
Thanks in advance!
bluzman2004 is offline   Reply With Quote
Old 11-17-2009, 05:29 PM   #2
markshaw70redBB
CF Senior Member
markshaw70redBB's Avatar
The front bars you describe are acceptable for certification if you weld a box or bracket of appropriate thickness to the interior side of the frame rail for the purposes of then mounting the bar to it. I can't recall the thickness of the plate but it should be at least 3/16" or thicker. I believe the NHRA rule book covers that thickness.
Besides peeling back the carpet and sound padding a cutout of the floor pan needs to be made in order to expose the frame rail. The dimensions of the box or bracket on mine are not large - maybe 2 1/2" square in order to support the bar. In essence you end up expanding the frame rail into the interior.
You cannot weld a plate to the floor pan itself.
Hope that helps. I can't get you a picture because I reinstalled my carpet over it and around the bar.
markshaw70redBB is offline   Reply With Quote
Old 11-17-2009, 06:20 PM   #3
bluzman2004
CF Senior Member
Thank you very much for that information. That is exactly what I was looking for. I saw in the NHRA book somewhere where it talked about attaching to something other than the frame and it had minimum dimensions for a mounting surface I believe.
I already have the rest of the roll cage tacked in and a square cut over the frame by the drivers foot, but when I saw that the frame was actually angled there I had to stop and do some research.
Old 11-17-2009, 10:19 PM   #4
2000-A4
CF Senior Member
Default Cage in C3
My door bars extend from the main hoop all the way up, through the floor and attach to the front frame. In place of the halo…the bar that runs from the main hoop and then along the top of the door window and down the “A” pillar attaches to the door bar. Then there is a short piece of tubing that intersects the door bar in line with this bar and connects to the side frame rail.
In the second to last picture you can see the passenger side door bar and the support that goes over to the frame. http://home.earthlink.net/~geaton/
2000-A4 is offline   Reply With Quote
Old 11-17-2009, 10:40 PM   #5
bluzman2004
CF Senior Member
That's a different approach. It looks like if fits pretty tight, too. Unfortunately, I'm using a kit so I'm stuck with my configuration. It's coming along pretty good and with some small tweaks it fits pretty good actually.
Those are really good times on a small block! Even your N/A times are incredible. Shoot, you are running faster than Hoche's car and he has a pretty large engine!
Thanks for the input on this guys. I just want to get this thing to pass tech so I can race some of the series they are having in our area next season.
Old 11-23-2009, 12:29 AM   #6
Ron Armstrong
Junior Member
Support Corvetteforum!
Thanks in advance!
[IMG][/IMG]
Ron Armstrong is offline   Reply With Quote
Old 11-23-2009, 12:46 AM   #7
Ron Armstrong
Junior Member
I welded a 6 inch X 3/8 inch plate to bottom of frame. I cut a hole in the floor big enough to be able to weld all sides. Also installed gussits or how ever you spell it. To the side of the frame to the plate welded to the frame. Welded the down bars first before the qussits. To make this easier, tack the cage together first then look at it to see what is the hardest to weld. Then cut the tack welds to move the cage around to final weld. Tack all of cage and look at it first and make a plan. If I can figure out how to send pictures I will.
Old 11-25-2009, 09:13 PM   #8
68 NJConv 454
CF Senior Member
68 NJConv 454's Avatar
Send a message via AIM to 68 NJConv 454
68 NJConv 454 is offline   Reply With Quote
Reload this Page C3 Roll Cage help?
Tags
bar, c3, cage, corvette, frame, race, roll, rollcage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any noticeable difference using Braided Brake Lines? Retro78 C3 Tech/Performance 16 05-23-2005 11:31 PM
Does anyone have a roll bar or cage in their C3? JD434 C3 Tech/Performance 20 12-22-2004 01:23 AM
Coil Overs Rkreigh C4 ZR-1 Discussion 65 03-23-2004 06:25 PM
Don't want to ruin it! sleveric C3 Tech/Performance 13 02-03-2003 09:29 PM
INterior Space C4 compared to C3? Light84vette C4 Tech/Performance 17 12-31-2002 02:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
