Cam swap question
1 Post
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Cam swap question
I know technically this is not a drag racing question, but I thought the chances are better someone here could best answer my question. I have a ZZ/4 350 cu .in crate engine and want to swap the cam. Since I'm going from hydraulic roller to hydraulic roller, what besides the springs do I need to change? The engine only has approx. 500 miles on it. I haven't picked a particular cam yet, but I'm looking for a little more performance than the stock one. BTW, this is in my '69 Camaro. Kevin
Hey Kevin...I called Comp and had a long conversation with them before I picked the cam for my camaro...I would give them a jingle..also try the folks at NastyZ28.com....hope all is well with you...
1 Post
St. Jude Donor '11
Thanks, Fuzz! I'm going to call them and Lunati also. I'm just afraid any dealer/manfacturer will automatically recommend changing them, eventhough they may not need changing. I've talked to three people who are knowledgeable engine builders and so far all agree the lifters are ok. Kevin
Yeah, with a hydrolic roller the lifters should be fine...I run a hydrolic flat tappet so I need to put in new lifters with a cam change...
When are you bringing it out to OSW fro a little shakedown?...he he he...
1 Post
St. Jude Donor '11
I talked to Lunati and they said the lifters/springs are fine. He also recommended the #60121 which is 219/227 @.050 and .515/530 and 112 LSA. As far as OSW... maybe the 'vette
