Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-20-2009, 09:30 PM   #1
black_89_vette
CF Senior Member
black_89_vette's Avatar
Send a message via MSN to black_89_vette
Default Who's got the best 60' time with a IRS C4?
Who has the best 60 foot times in a C4 still using the IRS? If you modded the rear end somehow for traction, please let me know how.
black_89_vette is offline   Reply With Quote
Old 07-20-2009, 09:57 PM   #2
INSANITY
CF Senior Member
INSANITY's Avatar
Send a message via AIM to INSANITY
My best 60' with the IRS was 1.35 but could not make a full pass without breaking something..
INSANITY is offline   Reply With Quote
Old 07-21-2009, 07:42 AM   #3
RichS
CF Senior Member
RichS's Avatar
My best is 1.48. Like Chris said things start breaking then.
__________________
96 GrandSport#857,Red Gut
Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60'
Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60'
397 LT4,Morgantini racing heads,3:73 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla...
2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11@112.18 w/1.71 60'
2010 White Grandsport ECS blower,meth and ZR1 cam 680rwhp/638rwtq 10.89@131.88 so far...
RichS is offline   Reply With Quote
Old 07-21-2009, 12:53 PM   #4
jpee
CF Senior Member
jpee's Avatar
I used to go 1.65 - 1.68 consistently with my C4 when I had the 3500 Vigilante, 3.73 rear (Dana 44) and 26" tires... That held up for awhile..
jpee is offline   Reply With Quote
Old 07-21-2009, 01:14 PM   #5
PDQUIK95
CF Senior Member
PDQUIK95's Avatar
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
1.58-1.61 consistently on a cryoed D44 IRS w/3.73 and Nitto DR's w/2800 stall and beam plates. 50 passes and so far so good.
PDQUIK95 is offline   Reply With Quote
Old 07-21-2009, 04:07 PM   #6
hookedup
CF Senior Member
hookedup's Avatar
1.32, next pass BOOM, clank-clank-clank!
__________________
hookedup is offline   Reply With Quote
Old 07-21-2009, 05:54 PM   #7
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
1.61 60'
__________________
John Mackey, National Corvette Museum Drag Racing Coordinator, Thanks to Carrolls Rod & Racecraft, Reher-Morrison Racing engins (412ci), Hughes PG. 9.797 @139.92 1.355 60'
mackeyred96 is offline   Reply With Quote
Old 07-22-2009, 07:58 AM   #8
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
1.41 car creations D44 jeb spool 3.90 gears,Dennys nitrous ready shafts,beam plates. 9.37 146 mph.Next run both half shalfs and outer spindel axles,both rear shocks boom and peppered everyone with needle bearings.Crew said car lifted 3 feet in the front as normal and 4 feet in the rear when it blew
It is only money
__________________
Johnny Carson once said.A married man may live longer ,but is more willing to die.
REDC4CORVETTE is offline   Reply With Quote
Old 07-22-2009, 11:48 AM   #9
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Are you guys running the Summer's Brothers 32spline subaxles?
I've got a rear wheel bearing going, and with my engine upgrade, it seems like a good idea and pull the trigger on upgrading my subaxles.
I emailed Summers Brothers about their kit and got the following.
Quote:
SUMMERS BROTHER RACING
KIT # DESCRIPTION COST
409200 1986 – 1996 C4 CORVETTE HEAVY DUTY AXLE KIT $1,300.00
COMPLETE KIT INCLUDES:
2 OUTTER REAR HUB ASSEMBLY – MODIFIED TO TAKE 30 SPLINES
2 OUTTER AXLES - MODIFIED THE SMALL STOCK STUB SHAFT, BORED OUT AND BROACH TO 31 SPLINES.
2 300M STUB SHAFTS AXLES – MACHINE 30 AND 31 SPLINES, HEAT TREATED FOR STENGTH, AND DURABILITY PRESSED INTO THE YOKE TO CREATE A HEAVY DUTY OUTTER AXLE.
409201 1986 – 1996 C4 CORVETTE HEAVY DUTY AXLE KIT $920.00
(Outter rear hub bearings and stock outer axles must be provided by the customer and we will do the modified.)
I'm seeing if they can do it with the new tapered bearings that are out.
BrianCunningham is offline   Reply With Quote
Old 07-22-2009, 01:01 PM   #10
Mr Mojo
Elite Torch Red Member
NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
1.67 with 2800 stall and stock Dana 44 with 3.45 gears and drag radials.
Mr Mojo is offline   Reply With Quote
Old 07-22-2009, 01:32 PM   #11
PDQUIK95
CF Senior Member
PDQUIK95's Avatar
Brian,
I'm currently running stock cryoed stub axles,but have a spare set of used stubs and new wheel bearings ready to send to Jose at Summers if and when I need them.
Rick
Old 07-23-2009, 08:26 PM   #12
timbradley26
CF Senior Member
who did you get the cryoed stub axles from ????? are they they worth going to ????
timbradley26 is offline   Reply With Quote
Old 07-26-2009, 07:44 AM   #13
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
1.33 with mine, but when I put the gears that should have been in it, both outside spindles broke on the launch.
Went to a solid rear and now the 60' times are a consistent 1.31-1.33 and never breaks.
ski_dwn_it is offline   Reply With Quote
Old 07-27-2009, 06:51 PM   #14
Red Rocket
CF Senior Member
Red Rocket's Avatar
1.64 60'. 396, ZF6, 4.09, DRM brackets, 15" BFG DR's 17PSI, beam plates, treated ujoints and spindles, 2500 RPM launch. No breakage in ten years of bracket racing.
Red Rocket is online now   Reply With Quote
Old 08-03-2009, 12:16 AM   #15
qwiketz
CF Senior Member
qwiketz's Avatar
I'd love to get into the 1.40's. Leaving off idle with a stock stall, my car goes high 1.60's on a 17" drag radial.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 08-03-2009, 12:26 AM   #16
hookedup
CF Senior Member
hookedup's Avatar
Quote:
Ooooooooooooooo, you shoulda' never said that, you've made the Dana gods very angry
But, by that sixty foot time its never dead hooked yet
Dave
Old 08-03-2009, 01:04 PM   #17
qwiketz
CF Senior Member
qwiketz's Avatar
Quote:
It is only money
So everything grenaded? Do you leave on the juice or on the motor? What power level is your car launching at roughly. Trans brake?
Man, I thought those parts would last better, but I guess not. Did the case last at least?
__________________
Old 08-03-2009, 01:04 PM   #18
qwiketz
CF Senior Member
qwiketz's Avatar
Quote:
Do you mean breaking something in the rear or in general? How did you get it to hold up to 1.35's?
__________________
Old 08-03-2009, 04:50 PM   #19
ralph
CF Senior Member
Some observations from years of experience:
1. If you have a stick and sticky tires and make any kind of power, the Dana is the wrong rear end. It will not make too many passes before it grenades.
2. I've seen several D44s go as quick as 1.30s, but they wont be reliable enough to race on the regular basis. Sort of like playing Russia roulette. Insanity would break the drivers side spindle on almost every pass.
3. 1.8s: D36 hit or miss; D44 will last for many many runs
4. 1.6-1.7s: D44 required to have any reliability. The D44 will become hit or miss, but several have lasted pretty long without problems
5. 1.5s: D44 will generally last about 100-200 passess at best. With cryo'd parts and good spindles and spicer ujoints they will generally last 200-300 passes. Eventually the spider gears will weld themselves to the shaft and break. Of course i've had one with good parts last 2 runs, then the case broke in half.
6. 1.4s: can be done with a spool, but the spindles and ujoints become the weak link. This becomes the point where a solid axle is necessary if you plan to race on a regular basis.
7. Stock half shafts are pretty strong, but i've seen them twist in half coming out of the burnout with a virtually stock car. So they can be hit or miss as well. Carry spares.
Good luck
__________________
Corvette Challenge Champion: 2002, 2005, 2007, 2010
"Satan" 406: 10.8 @ 124
ralph is offline   Reply With Quote
Old 08-03-2009, 10:23 PM   #20
Red Rocket
CF Senior Member
Red Rocket's Avatar
Dave
LOL,
Only one goal with my 396-- winning trophies in the Pro Class of the Texas Muscle Car Challenge Bracket racing series. Only need to run in the 11's in the 1/4 and 7.63s in the 1/8 to be in this class. Lite spin of the tires and a 1.75-1.8 60' are all I need. Plan to race another 10 years without any breakage.
Reload this Page Who's got the best 60' time with a IRS C4?
Tags
1995, axles, c4, corvette, duty, heavy, hill, irs, john, jr, mackey, racing, sepanic, spring, tn, transmissions, vic
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Drag Vette Suspension Who's Got one vette75406 C3 Tech/Performance 14 06-30-2004 12:04 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
